I bought a new thumb drive and saved my graphic on to it, but when I tried to bring the graphic up on the screen, from the thumb drive, it said there were 0 bytes, so I assume it did not save. What might I be doing wrong?
  • 39 Answers
Right click the thum drive and look for the format tab open it and select quick format, then apply and hopefuly that help and then try and save agen.
Posted on Sep 13, 2008
HP pavillion a6300f pc when powered on, the fans come on and can feel the hard drive spinning, however there is no video output; I took the pavillion to another pc monitor and same result, no video output....
If it shows the bios on your screen.... Try to go the bios setting and make check the "default operation" and save upon exit.
Check the Motherboard, if there are swollen/bulging capacitor on the board, replace it.
If there are no bios whatsoever, sad to say, problem will be the board already......usually the bios chip that breaks down.
Try to use another power supply, sometimes the power supply is the culprit of the boards problem.
Hope that helps you out!
Aug 09, 2011 | HP GX613AA Pavilion A6300F Desktop PC
Cracked the screen on my palm centro is there anyway to fix the screen or save the pics i had on it?
take the phone to the shop you bought it from and ask for them to fix it. it may come under warenty if it were acsedental, depends weather the pictures were saved to your sim or phone, either way if your phone came with a USB cord you can plug it into your computer and follow the prompts to save them on your computer and once you have done that you can save your pictures to a USB thumb drive and take them everywere you go, and after that if you ever get a new phone you can blug your phone into the computer were the pictures are saved and put your old photos on your new phone (
Apr 25, 2010 | AT&T Palm Centro Cell Phone - White
I need an ati driver hd 2300 for vista
Yes there is a solution, pop the restore cd rom (the one you got when you bought the computer) into the disc drive and restore windows, that will reinstall everything, but you will loose whatever you install after you bought it and you need to save stuff in your document folder to a thumb drive first. Or you can purchase the new window 7 OS. Always make sure you have an antivirus program running. Contact me if you need further help.
Mar 13, 2010 | Computers & Internet
Desktop is not the same -- it is elongated and smeared and I cannot see shortcuts when i turned it on today. I heard the Microsoft music, but cannot
Have you tried right-clicking on the desktop and checking your graphics settings? It should be no more than 1020 X 768 resolution and it may be even lower than that to fit your small screen size. If this doesn't work, you may try to reinstall the video (or display) driver from the manufacturer's website. Use a Thumb or flash drive and save the driver install file from the maker of the laptop and try loading it manually. If this doesn't correct the issue, it is likely you have damaged your LCD screen.
Mar 09, 2010 | Samsung NC10-14ROBL Notebook
No Signal and BIOS troubles - new video card
try using the onboard graphics instead and remove the graphics card. then uninstall all the graphics card drivers and software and reinstall again. make sure you install 32bit or 64bit depending on what your operating system is. you can find out if it's 32 or 64 bit in the welcome center of vista.
Apr 05, 2009 | Acer X193W LCD Monitor
I have bought and installed a new HDD. I have partitioned it. I'm running windows xp setup. XP Setup begins installing windows gets completed...then system restarts and monitor looses display. this is the...
Hi there
I think it may be a graphics problem. May be the XP drivers are not compatible with your machine graphics card.
You could try this to solve it ...
From the web, possibly on another PC that's got the internet, download the graphics driver for your machine and save it to a USB disk.
Once the set up is complete, try booting into safe mode (press F8 on boot, then select boot into Safe Mode)
Now try running the driver from the USB disk (or copy it to C: drive first then run it).
Jan 09, 2009 | E-Machines (T2824) PC Desktop
Windows Xp SP2 prpgress bar freezing
You must uninstall the drivers of your old card before installing the new card and drivers.
Also make sure the BIOS is set to automatically check what you are using, onboard video (if available) or graphics card.
Jul 24, 2008 | ATI RADEON 9250, (256 MB) PCI Graphic...
PNY Optima Pro Attache 4 G
Make sure you are using the right port. There are slow and faster ports on a laptop.. So try plugging it into another and see if it helps
Jul 18, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Fisher Price Digital Arts & Crafts Studio
This is a video card issue. First, this needs at LEAST 64meg of RAM. If you do, do the following:
1. Bring the "Display Properties" dialog window (right-click on the desktop, click on Properties)
2. Click on the "Settings" tab. (make sure your screen resolution is set to 1024 by 768, and the color quality is 32 bits)
3. Click on the "Advance" button (this will bring a new dialog box)
On the newly opened dialog box:
4. Click on the "Troubleshoot" tab
5. Set the "Hardware acceleration" to "Full" (drag the slider all the way to where it says "Full")
6. Click "Apply", then "Ok" (this will close the dialog box)
7. Close the "Display Properties" dialog window by clicking on the OK button.
Try turning the toy ON now. I hope this helps.
Dec 25, 2007 | Adobe Photoshop 7.0 for PC
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
