Hello.
Please apply the solution this way!
To
close an oven door when it's in the locked position and the door is
open, press and hold the oven door light switch while following these
simple steps:
To self-clean your wall oven, follow these simple steps:
Note: For safety reasons, the oven door will remain locked until
the oven cools down. When it is sufficiently cool, the door will
automatically unlock.
Thanks for using fixya.
Testimonial: "THANKS SO MUCH...you were very helpful. And a quick response. Bless you. Dianne"
Hello, have you ever used the cleaning cycle on this electric range? If not,
then look under the burners cover (top of the stove) on the top and above the
oven door. In the middle there will be a black hook, might be kinda hidden. Pull
the hook 140 degrees in the opposite direction. This will unlock your oven door.
While clean the door, but I won't mention here, invertenially lock the door
and the over started it cleaning cycle. While oven is in it cleaning cycle for 2
or 3 hours, you can't open the oven door. It has a timed door lock once in the
clean cycle. Also, it won't let you open the oven after cleaning cycle, until
the oven cools down for about 45 minutes to 1 hour. (cleaning cycle temperature
in the over will be approx. 1500 to 1800 degrees) This is why the oven is
cleaned, it burns off the brown/black grim. Also, there are cleaners to get the
brown strikes off across the glass in the door. The glass is high temperature
and anti shatter, and it very expensive. All oven door will have a manual lock
on the doors....This a safety factor for kid the like to get in the ovens it
also the same with freezers and refrigerators. I hope this help you. GB
you...stewbison
