Question about Sanyo DS36930 36" TV
Lightning After a storm the TV will no longer power, I removed the rear panel and checked the fuse. It is fine and I have power to the fuse location, however can not get the TV to power on?????
  • 4,234 Answers
Power hits are very difficult to recover from primarily because odd things can happen. Usually the standby transformer or power supply takes the largest hit. With no symptoms to go on, it is difficult to provide a diagnosis remotely. If you have any electronics experience, start by looking for the standby 5V inside the set. If that does not exist, start with getting that portion to work. After that, hopefully the set will attempt to start and we can continue from there.
Dan
Posted on Sep 15, 2008
Stopped working after a storm
Did you have a power surge after a loss of power? If so your TV is ruined from the surge. In the future use a surge protector if don't already.
Aug 20, 2016 | Televison & Video
Polaroid TLA-01511C stopped working after electrical storm. Will try to change fuse, if I can get to it. How do I access the fuse? NOT equipped mentally or with tools to do more.
Contact any service technician. The fuse can be located at itw main power regulator board inside. If the power supply regulator board is found faulty, it will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
Aug 07, 2014 | Polaroid TLA-01511C 15 in. LCD Television
Vizio M420nv LCD TV Black Screen
lightning can do extensive damage to electronics equipment especially flat panel TV's. I would really recommend a professional diagnosis instead of board swapping. You could have several boards that are damaged!
Feb 13, 2013 | Vizio m420nv 42 in. LCD HDTV
Samsung tv lightning strike reset
It is likely the ac fuse which the power cord goes directly to got hit.
back would have to be removed and fuse checked.
Mar 18, 2012 | Samsung Televison & Video
My tv went dead during a lightning storm. I heard
The sound could have come from one of your power capacitors. You could tell if one of them is no longer operational by looking at them; they will be burned, or blistered, or will be bulging. If this is a CRT type of TV ensure that you only look inside if you are fully aware of how to deal with the lethal voltages that are stored on the inside of the unit.
Aug 09, 2009 | JVC AV-32850 TV
Av-48p776 rear projection jvc. power surge from a lightning storm
You will need to replace the convergence chips located inside the set. Typically a repair shop will charge 150-250 to fix it. Good luck
May 16, 2009 | Samsung HC-P4752W 47" Rear Projection...
Someone please help
Good Day;
Two things normally happens after a L storm:1.) One must unplug TV for 5 minutes, then plug back in. 2.) Main glass fuse out, will be near a/c cord. 3.( Power regulator IC may be out. Try these first.
Good Luck!
Jun 13, 2008 | Panasonic PT-52LCX66 Projection Television
Tv will not turn on after lightning storm
Defective HV transformer. (Likely lost it during the storm)...accordianman
Nov 28, 2007 | Orion TVDVD092 9 in. TV/DVD Combo
check IC location 7532, Diode locations: 6536, 6562 IET, Inc.
Aug 06, 2007 | Philips 32PT6441/37 32" TV
Sanyo DS36930 36" TV Logo
53 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
