Question about RCA MM32110 TV
Loose Picture (Goes completely Black)
RCA MM32110 televison purchased 4 to 5 years ago. Picture will come on then will go black. It losses green and blue color (turns red) for a second before quickly fading away. I can change channel or turn set off then on and picture will be fine.. then go black again....sometimes within seconds sometimes plays for several minutes... sound is fine when picture disappears... HAD set diagnosed and was told that the dual layer video board needed to be repaired and it would cost $550... Seems way out of line!!!!!!!!!
    President:
  • 3,130 Answers
Nothing special about that board as I cant seem to find that # but If my memory serves me correctly it sounds like a crt board and its a simple soldering job on the crt socket?? Altough Im not there to see the set still 550.00 seems like an awfull lot to repair a set even if they have to replace the entire chassis. I think you should cal rca and take it to an authorized RCA repair center and if the shop you took it to was an rca authorized center I would also report that to them(RCA). Good Luck
Posted on May 17, 2006
SOURCE:
No video but sound on my tv. When I reset it the picture shows for a sec then goes off. This happens every 20 sec or so for about 4 times then goes back to black
You have either bad LED lamps in the panel or its possible you have power supply issues as well, but generally its the lamps that fail
Mar 15, 2018 | RCA Televison & Video
RCA L32HD41 LCD TV. I had purchased this Tv about two years ago. Now there are white lines going down the tv sometimes they come and go, and sometimes it stays in the middle then moves to either side of...
Hi Mirna,
This problem is due to loose contacts in the LCD panel in your TV. To fix this, the TV has to go to Panel repairing machine (tab bonding machine). I hope it helps.
Good Luck.
Feb 06, 2018 | RCA L32HD41 LCD TV
RCA mm32110 picture turn to blue and white like you have blue sunglasses on.
I'm not familiar with this set but it sounds like your blue crt has shorted out and is putting out so much color that it overwhelms the other colors. Is the picture also washed out? If so then your blue crt is bad. Probably not worth fixing. Let me know more about what the picture looks like.
hardrocko
Jan 31, 2010 | RCA Televison & Video
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
Black Screen after 5 mins. of use
Question when u loose picture do u loose sound also ? If so there is an 27Mhz xtal on the (SSB) small signal board that needs to be changed when it heats up it cycles out of phase. when it cools down it will work again till it heats up.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Apr 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA MM32110 TV Logo
93 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
