Question about Hoover Vacuums
How can i disasemble the handle from the vacum
  • 706 Answers
Http://www.hoover.com/pdfs/manuals/U6634900.pdf This may help.. if you can provide a specific model number.. then I may be able to provide details on how to disassemble yours.. Hope this helps...
Posted on Sep 13, 2008
Handle release has stuck down and want release handle
http://canada.bissell.com/FAQs_and_Answers.aspx go to web and see all information, video, troubleshooting, questions, and fix it.
God bless you
Sep 22, 2012 | Vacuums
How to install handle release button on eureka vacum cleaner model# 4870
Eureka 70042-355N Handle Release Pedal for model 4870
costs online anywhere from >99cents to $9.00.
here is a great discription found after much looking.
http://www.fixya.com/support/t4508530-eureka_model_4870dt_r_nplastic_foot
Aug 30, 2011 | Eureka Smartvac 4870 Bagged Upright Vacuum
ComThe vacume handle is very difficult to get out of the upright position. It use to take just a gentle tap on the front of the vacume to release the handle. Now I have to stomp on the vacume front to get...
Sorry to hear you're having difficulties with your DC14. The cleaner should recline easily into the vacuuming position when one foot is placed on the cleaner head, and the handle is lowered. If it's not doing this, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 15, 2011 | Dyson DC14 All Floors Upright Vacuum...
When I step on the head so that vaccum enguages it stops sucking. You no longer hear air being sucked through the handle as well, the head does not **** down to the floor. When you lock the handle in the...
near the bottom of the vacume where the hose bends down to the floor sweeper, check to make sure there is no blockage. this is the most common problem with vacume suction. you can use a wire coat hanger to help loosen the dirt and debris from the line and it is sometimes easier to clean properly if you remove the bottom plate ( like you would if you were changing the belt ). also while you are getting dirty and having fun, this is a good time to clean the air filter, ( tap it out good or/and use a brush or air compressor to clear and clean ).
c...
Dec 31, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Cable is stuck in the vacume s 1361 hoover
Unplug the vacuum from the wall. Disasemble the brush assembly. Usally there are 2 screws, one on each side. Manually reverse the brush and dislarge the cord. Inspect the cord to make sure its not frayed or exposed wire before reusing.
Ed " Original Radio Man"
Nov 20, 2010 | Hoover Vacuums
Replacing broken handle on filter queen vacume
It is always best to have a cirtified & Authorized Service Tech or Center do the work and only with genuine Filter Queen parts and supplies. Both can be found at 800-344-1840 or in Iowa 888-637-4692
If a Authorized Tech can not come out,
  1. Always unplug unit from electric outlet.
  2. Remove top like you were changing filters, also the crown.
  3. Remove cap under handle.
  4. Remove 3 screws from SN plate then remove plate.
  5. Seperate upper from lower.
  6. lift cardboard piece and Silencing Filter.
  7. Now you can remove the 4 screw that hold the handle.
  8. Repace handle and reverse the above steps.
FQ Master
1-888-637-4692 in Iowa
Your Authorized Filter Queen Service & Supplies
Apr 04, 2009 | Filter Queen Majestic Canister Vacuum
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Self propelled wind tunnel vacum will notpropell itself
Must be a Hoover, The flat belt may look ok but I am sure it has stretched to the point where under load it won't drive the wheels or the brush roll. Could also be a bad brush roll.
Nov 06, 2007 | Vacuums
Brushes don't turn
i once was a vacume salesman and i have handled a lot of differnt kinds of vacumes there are a few things that will make the brushs not spin the belt could be broken is some there is a swith that when you lower the handle will turn on the brushes. or if the vacume is on the barefloor setting in somecases they also wont spin i hope this helps.
Nov 11, 2006 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
