Question about Compaq Computers & Internet
I've disconnected the wires in my compaq 5000. Where can I get a wiring diagram so I can put it all back together?
    Sergeant:
  • 320 Answers
This is very simple. Click on below link or copy the URL and paste it in your web browser and follow the steps. Be careful while connecting power cables.
"http://images.google.co.in/imgres?imgurl=http://www.ezbuildyourowncomputer.com/BareBones1%2520010%2520FrontPanelConnectors.jpg&imgrefurl=http://www.ezbuildyourowncomputer.com/RemoveCover.htm&h=270&w=360&sz=14&hl=en&start=4&um=1&usg=__upxkxY8-vUBhZ6uEFumejvwWcxE=&tbnid=qlpCOg4zFD3zbM:&tbnh=91&tbnw=121&prev=/images%3Fq%3DMotherboard%2Bmanuals%2Bfor%2Bpower%2Bconnections%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26sa%3DG"
Thank you...
Posted on Sep 13, 2008
Need a wiring diagram for a 1997 Nissan quest xe fuel pump assembly it has 4 wires and my not so smart brother in law tried to change fuel pump abd instead of disconnecting the plug he cut the wires so I...
Usually, replacement pump will come with wiring instructions. If dumbo lost them, might go to friendly parts store and ask to look at chart in another one, or simply look at wiring diagram in your shop manual.
Dec 15, 2014 | Cars & Trucks
Dodge dakota problems
Yes, there are wiring diagrams.. they are specific for your year truck... use one of these... they will have the wiring diagram - since this is a ECM component, the wiring has to be perfect.. or you will end with "service engine" light on all the time...
Dodge Dakota Service and Repair Manual from Chilton Official Site of...
Sep 08, 2017 | Cars & Trucks
Kenmore heavy duty washer model awiz wiring diagram
There is a wiring diagram inside the washer usually inside the control panel.
Jun 26, 2017 | Washing Machines
I AM LOOKING FOR A WIRING DIAGRAM FOR A COMPAQ PRESAIRIO 5000 ON OFF, RESET AND LIGHTS ? WHERE CAN i GET THEM.
Hello mr_billsauto
The Compaq and HP cases have a block connector for the front panel. On the main board there is a set of pinns usualy labled as fpanel. that is where you connect the block set.
If the motherboard is the original then it should match the attached picture. I have circled the location of the connection.
Good luck
If this was helpful please leave comment, feed back.
Feb 15, 2011 | Compaq Presario 5000 PC Desktop
I ran over rock and tore my oil pan. oil leaked engine hot. i shut off. i have removed and repaired pan, disconnected rods, freed up, everything turns pistons up and down. put everything back together and...
Similar to a vehicle starter, there has to be two positive wires attached to the positive terminal on the starter, and then there has to be a ground wire. A starter will not operate if there is no ground wire connected.
Aug 11, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
MY CAR WONT START BECAUSE IN AFTER MARKET ALARM. hOW DO i BYPASS THE ALARM TO START THE CAR
I've ran into this problem myself, if you're not confident with doing some wiring you probably should not be doing this. This will probably take 1 to 3 hours to do this. If you can get a wiring diagram that showed how the alarm was originally installed. If not find the alarm probably underneath the dashboard, the alarm wires will problem be smaller than a wiring that is in your car. When removing the alarm think of it as this way, someone cut into the middle of your wiring harness and put a alarm in. Would you need to do is remove the alarm and splice the cut wires back together. Instead of removing the alarm all at once try disconnecting one wire in a time and finding its mate. The wires or color coded. For example, black with an orange tracer. This would mean it's a black wire with an orange line on it. If you're not sure look at a wiring diagram splicing the wrong wires together could cause your car not to function properly or damage it. Before you start this make sure you disconnect the battery also. Good luck.
Jul 18, 2010 | 1998 Ford Mustang
How do you put wires back together for the windshield wipers?
Were the wires cut? Most are color coded (with stripes) and you can match them up. If you just have a bunch of loose ends, then you can check your local library for the Chilton or other manual that has a wiring diagram for your model.
Also, a local dealer may be willing to make a copy of the wiring diagram for you.
May 19, 2009 | 1993 Toyota Corolla
Wiring for compaq 300 watts power supply
PCs these days are built so that cables only fit one way in one place where it should be. Just take your time, and don't force, but do apply pressure while inserting the cables into the correct slots.
Jan 24, 2009 | Compaq Presario 5000 PC Desktop
Fixing the hard drive box
i can walk you through this. if you send me some pictures to netrecov@yahoo.com of the inside of your computer i can indicate which wires goes where.
Apr 29, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
