Question about Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera
Cannon sd800 is
Lens error appears and the lens will not come out.
  • Anonymous Apr 07, 2009
    I had this problem, banged the heck out of it and then finally forced the lens back in. I got it working again although the lens does not close 100 but my pictures now are very blurry.
    Any futher suggestions before i toss it out the window?
  • 2,071 Answers
If your camera is still under warranty, the best thing you can dois to take it to the nearest official repair shop and Canon Digital Cameras shouldfix it for free.
If your camera is out of warranty, or if Canon refuses to repairit for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some ofthe methods listed here to repair it yourself. These simple methodshave helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon Digital Cameras has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon Digital Cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras.They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 13, 2008
  • 32 Answers
This might help.
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Posted on Dec 02, 2010
My cannon finepix S4200 camera wont zoom in or out I also get message "turn of camera and remove lens cap or obstruction from lens" but no lens cap fitted and there doesnt appear to be any obstruction...
The sensor or logic board in the camera must be fooled, or one of them is defect.
When removing and reinserting the battery does not change this, contact a Canon certified repair centre and ask what it will cost to repair this error. Then decide if you want to spend that money for repair or as a start for a new camera.
Mar 29, 2015 | Cannon Cameras
No picture when i use camera then will appear the e32 error then shotdown
lens may be slightly experiencing a focus error . try cleaning the lens and contacts .
or set the switch to manual focus
Jan 27, 2014 | Cannon Cameras
Canon power shot SD800 Is digital elph. Lens is stuck in the extended position with lens error reading
You need to have the lens assembly replaced, it's the only way to fix the problem. It's about $75-85 total for a refurbished lens, installation and return shipping of the camera.
Thomas Drayton
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Sep 07, 2011 | Cameras
Where can i buy the outer ring lens cap for a sd800
try this link hopefully you will find what you are looking for http://www.darntoothysam.com/products/Canon-Powershot-SD800-Camera-Lens-Ring-Trim-Repair-Part.html
Oct 07, 2010 | Canon PowerShot SD800 IS / IXUS 850 IS...
When i turn on camera it says "lens error, restart camera". And the lens won't go back all the way in.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 02, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
My Canon Powershot SD800 IS, has had its lens stuck as if it were zooming out.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 10, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
I have a canon powershot sd800 IS and the  lens appears not to want to close! The camera is just over a year old and rarely used!
Jan 24, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Error on lens
Jan 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error, restart camera
http://www.ixus-world.de/index.htm?tips/repair_guide/e18_01en.htm
Aug 02, 2008 | Canon PowerShot SD800 IS / IXUS 850 IS...
Installing the powershot SD 800 IS
Hi Linda. Canon makes the software available at their website, let's see if i can post a link here for you:
<a href="http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=14227">Clickity</a>
Hope this helps
--Deb
Jan 06, 2008 | Canon PowerShot SD800 IS / IXUS 850 IS...
Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera Logo
190 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
