Question about Microwave Ovens
My Panasonic Microwave Oven Model # NM-6953 will not rotate or microwave at all,but all the timers, clock ect works perfectly
  • tillicum Sep 13, 2008
    I much appreciate your advise in regards to my problem,but since the unit is not in my home I will not be able to apply it until next weekend.
    Thank You.
  • Microwave Ovens Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 13, 2008
  • William Miller
    William Miller Sep 14, 2008
    I look forward to hearing back from you and seeing your rating of my solution once you have actually applied it.
How to reset the clock on a Panasonic NN-SA651S microwave.
hi carol.
try this,if this does not work go to the link.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set. You are now ready to use your new Panasonic Microwave Oven. When you first turn on yourmicrowave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . .
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How to reset the clock on Panasonic NN SA651S microwave Google Search
Nov 07, 2017 | Panasonic Microwave Ovens
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 10, 2010 | Sharp R-1214 Microwave Oven
Unit operates does not heat anything
A defective diode or magnetron can cause the oven to sound differently and not to cook.
Jun 19, 2010 | Whirlpool MH6130XEB/Q Microwave Oven
Panasonic dimension4 microwave
check the damper motor is opening and closeing
Jan 17, 2010 | Panasonic NN-T888S Convection/Microwave...
Microwave only runs for about 3 seconds.After
Chances are you have a failing magnetron.
But to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "Microwave only runs for about 3 seconds then stops and the timer goes back to the clock mode.After several attempts then it will work.Problem is intermitten"
Dec 04, 2009 | Panasonic NN-S252WF Microwave Oven
The microwave works for only 8-9 seconds, then stops
It may be in demo mode.  On some units if you hit the timer/clock button 4 times to turn demo off.
Feb 02, 2009 | Panasonic NN-C994S Convection/Microwave...
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
93 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
