Question about Dryers
How to install the belt on a Maytag Dryer modek MDE9420AYW
I need a picture of how the belt goes around the tube and pulleys, also how does the flange on the Idler pulley face?
  • 706 Answers
This should give you a few ideas on how it works.. Hope this helps...
Posted on Sep 13, 2008
I have a Maytag SE-1000 stacking washer dryer setup. I am trying to replace a broken dryer belt, and have the disassembly done, and the replacement belt in place. My problem is trying to understand how the...
Most dryers are tension idler pulley directed but must first go around the grooved pulley on the motor shaft. make sure the idler goes on the smooth side of the belt and the grooved side of the belt is in the grooves on the motor shaft.
Oct 13, 2013 | Maytag Dryers
Tip
Maytag Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For all single belt models use this diagram:
Style: Flat with ribs
Installation Tips: Flat side of belt against drum
on Mar 06, 2010 | Dryers
I took the dryer apart and lubercated the belt and now I cant put the belt back on. How do I do this?
Hi buttcrackplu...
The belt will go around the drum,around the motor and idler pulleys....
Go to this webpage to see how the belt is routed.
Free Answer.,..Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Apr 18, 2011 | Maytag Neptune MDE4000 Electric Dryer
How to install belt on Maytag dryer
The motor pulley usually has grooves and the gooves must match on that pulley. The belt goes around the drum gooves down thur the tensioner and on the motor pulley.
Sep 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Belt installation for a maytag dryer model# sde305day
Usally put dryer belt around the drum first
then around motor the tensioner pulley has to to be pulled up when you do this to get the belt around tensioner then you release the tensioner pulley to put tension on belt
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
DIAGRAM OR INSTRUCTIONS BELT INSTALLING MATAG DRYER DE412
belt goes around drum and around pulley on motor and under tentioner
Feb 18, 2009 | Maytag Dryers
Which wa does the belt on a Maytag Atlantis dryer run around the motor and idler pulley. I have the belt groove side down, which is the way it goes in the Atlantis, but I couldn't find a schematic for the...
Hi you're correct in putting it groove side down. Now make a loop, like when you first started tying your shoes with the slack around the drum. Push the entire loop just beneath the idler pulley through the metal channel and apply pressure to the idler pulley assembly. pushing it towards the motor pulley until you can get the loop you are holding over the motor pulley and Waa Laa you've installed your new belt. Good Luck!
Dec 10, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
The Maytag Dryer MED5570TQ0
Hi lesterjabbow;
A lot of these dryers have a long fiber belt that runs from a pulley on the motor thru a tension idler pulley and goes all around the drum. I suspect this belt is either broken or has come off the drive pulley on the motor. You can remove the back of the dryer easily with a 1/4 or 5/16 nut driver and immediately see if the drive belt is good. Any Maytag dealer will have a replacement part and it is easy to install
Hope this helps Good Luck Loringh PS Please leave a ranking if appropriate Thanks
Nov 22, 2008 | Maytag MED5770TQ Electric Commercial Dryer
Neptune Maytag MDE9700AYW
Remove the screws from the bracket from the vent tube at the back of the dryer.
You can access the belt from there.
If the belt is off then the tensioner will push a switch to shut the dryer down.
Just hook the belt back on or replace the belt whatever needs to be done.
See other posts for this model number on how to connect the belt back if it came off.
They do that when turned the wrong direction.
Oct 11, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Electric Dryer - replace belt
The belt needs to be above the metal. Otherwise the repair looks good. Easy fix. Thanks for the pic.
Oceti
Jan 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
569 people viewed this question
Top Dryers Experts
