Question about HP LaserJet 2200dn Printer
Printer problem I have a HP 2200 dtn laser printer that is printing the information lean on the document. How do I fix this?
My laserjet2200 DTN does not print and constantly the orange light is on , despite I did change the cartrige. When I switch it on and off the green light comes, but when I try to print something the orange light comes again.
Help me please.
Regards
Posted on May 15, 2008
Hi the problem with hp 700 printer/scanner/copier is that the kids pulled out a clear plastic ribbon and a white plastic strip which is normally conected to the chip board i guess the question i would like to ask is can this problem be fixed or do i need to buy a new printer. Thanks reagards fran
Posted on May 29, 2006
  • 215 Answers
Could he mean it's printing faintly. In which case the machine could be out of toner. BMW
Posted on May 18, 2006
  • 513 Answers
I would like to help, but what do you mean by "lean on"? I'm sure it's probably a typo, but I can't figure out what it's supposed to be, my neural connections aren't working I guess ;] Please post a comment with an explanation, and we'll all do our best to help.
  • yoav kleinfeld
    yoav kleinfeld May 18, 2006
    Maybe you mean lean as in narrow? thin?
My printer HP LASER JET 5200 DTN shows "Ready" on the display but it doesn't print, how can I fix this?
First thing you need to do is establish whether the print engine itself is at fault, or not.
From the relevant printer front panel menu, invoke printing of one or more of the available reports (configuration, font list, etc.); do these print?
If the reports print OK, try to send some plain text to the device.
On a Windows system, you could do this by using the DOS copy command in conjunction with an appropruate net use command to redirect LPT1: to the (USB) port associated with the relevant Windows printer instance.
Jun 02, 2015 | HP Office Equipment & Supplies
Hp laserjet 4300 dtn tray one pickup
Yes,
Adding the duplex attachment makes the TN a DTN nothing different in the firmware of the printer.
Feb 05, 2013 | HP LASERJET 4300DTN Q2434A LASER PRINTER...
HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Jan 05, 2010 | HP LaserJet 4350dtn Printer
Error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
May 21, 2009 | HP Office Equipment & Supplies
HP Laser 2200 Cannot print one page or a range from a document
Dear,
I think the problem is in the printer setting, so just uninstall the Printer(Driver). Restart the PC and reinstall the driver.
It may solve your problem.
Regards,
Rakesh Kumar
Apr 09, 2009 | HP LaserJet 2200 Printer
Adding IP addresses to a HP 5550 DTN printer
ok then install that printer as a network printer to one pc share ti and ad to as much pc you need after that without ip adress
Dec 10, 2008 | HP 5500 Color Laser Printer With Internal...
HP laserjet 4350 DTN Folding corners
teflon coating on heat roller in fuser is coming apart. replace the fuser. also check to make sure the paper tray is set to the correct size. this means pull the tray out, remove all paper, look inside to make sure the arrow is pointing directly at the correct media size you are using i.e. letter or legal or whatever you are using. Good Luck! please rate this carefully.
Oct 09, 2008 | HP LaserJet 4350dtn Printer
HP Laser Jet 2200 dtn - Print Quality
For troubleshooting "ghost printing" use "LaserJet 2200 repetitive defect ruler". Measure the distance of 'ghost' figure from the 'original'
Try this link:
http://www.printertechs.com/tech/repdef/ruler2200.php
Jan 05, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 2200dn Printer Logo
261 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
