HP Hewlett Packard HP DVD557S 8x USB Slim DVD-RW LightScribe Black Burner Logo
Posted on Sep 07, 2011
Lost the software cd for HP dvd557s DVD Writer only find the firmware update not the software (orig) where can I find it please and thank you
2 Related Answers
Anonymous
  • 65 Answers
  • Posted on Jun 24, 2008
SOURCE: lost mydvd writer software disc
hi sandy.....
first open dis site....
http://www.brothersoft.com/downloads/nero-7.html
n download nero 6.6.1.4
n its seriall no. is:-
1A23-0009-6030-2391-0264-0105
ask me if u r havin more problems....
thanks....
Anonymous
  • Posted on Jan 30, 2009
SOURCE: HP DVD 1040i
on the back of the hardware are jumpers
mine are located next to where the ribbon plugs in
there are 3 jumpers- like this : : :
the jumper must be on "cable" ( printed above post )
just move the jumper and reinstall
Now xp can find the 10401
I did it...it works
1helpful
I need the install cd.
HP ended support at VISTA I am told.
got VISTA>??
the OS on your PC is OEM and not sold now, anywhere.
why not ask this at HP and not here.
ask them and hear the NO word from them GOD of HP.
btw , no PC told at all nor one clue what OS is there.
HP DVD557S is and external DRIVE.
is the PC ok, is that it and lost the drivers for the HP DVD557S
is that it.?
no internet means you lost the 2d path to drives. CD drivers or internet. gone
we go to a 2nd good PC with internet
and find the drives and put them on a thumb drive.
then move them to the off grid PC. failing
its 12 years old this drive. DVD.,my guess w7 driver disk
cam in the box new, LOST THAT or just bought a used DRIVE.DVD
the problem for you is no internet
making PnP plug and play dead and the drive with it born dead.
PnP is not an option nor is internet an option.
if you add any device new to any PC the internet must be working
or the new device fails most the time.
a PC101 factoid.
call HP and for the CD with the missing drivers.
here is the best answer of all
asked by others
"Hi,
HP supplies the Drivers for their Hardware.
You need the Drivers to make the Computer and HP's Hardware work together.
HP stopped Support and supplying Drivers for that Hardware at Vista.
http://support.hp.com/au-en/drivers/selfservice/hp-dvd-writer-dvd500-series/5244296/model/5057686
For any more information I suggest that you ask in the HP Support forums.
http://h30434.www3.hp.com/psg/
if you go to HP.com you see the erased every word about it
there forum has echos of the past on topic but no drivers now
they erased all vista and XP suppot
w7 next.
I have an HP DVD+R/RW 16x10x32x4x2.4x8x Drive and i am trying to find the drivers for it to see if it works on my computer. I have tried typing up the Product Number and HP Part Number on the HP website,...
DVD-RW 16X HP DVD Writer 740b Drive Firmware Update ftp://ftp.hp.com/pub/softlib/software7/COL16063/pv-42566-1/sp26595.exe
you must be logged in as the computers administrator to install this update
or
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07165&cc=us&dlc=en&lc=en
Update your HP desktop computer to have the latest software and drivers available. HP provides many software and driver updates free of charge
hope this will help you
  • You must be logged on as an administrator to install this update.
  • HP DVD Writer 740b drive.
  • Blank floppy diskette, recordable CD (CD-R), or USB Thumb Drive.
  • Released: s.gif 2006-08-23 Version: s.gif HI24 Compatibility: s.gif Microsoft Windows XP
    Its not reading Maxell writeable DVD's
    There is software "inside" the DVD-writer.
    It is called "firmware".
    The firmware reads the "label" off each disk,
    to determine capacity, maximum recording-speed, and such parameters.
    So, you need to access http://support.hp.com and search for updated firmware for your HP device, because the current firmware is _not_ recognizing the label on that one specific brand of "blank" media.
    Updating the firmware will allow the recognition.
    Hi: My computer is not recognizing my ts-h492a
    Please go here and download the live update from Samsung. This software is designed to automatically update you to the latest firmware via the internet. To get this service, customers have to install the Firmware LiveUpdate program on their computers.
    Please download the live update full version if you have not used this software before. See link.
    http://www.samsungodd.com/Eng/Firmware/liveupdate.asp
    Simply follow the instructions as given and your software will be updated to the latest version required to run your CD/DVD writer with your computer.
    Hope this helps. If so please do leave a vote for the solution. Thanks.
    1helpful
    HP DVD 1040i
    I would email or call hp support and ask about this as there should be a firmware update of some description.
    Also re install latest chipset drivers and maybe adaptec aspi drivers ?
    1helpful
    Change the dvd writer speed
    you did not specify the company name of your writer.
    you can change the speed of your writer using a tool called Media Code Speed Edit (MCSE) which is able tomake your DVD writer read and writer faster. If youhave LiteOn, Benq, PHILIPS, HP, LG, NEC, newer PIONEER, Cyberhome,Gigabyte, Samsung and Artec DVD writers, you have a good chance to playwith MCSE and speed up your drive.
    MediaCodeSpeedEdit allows you to change the write speed for your mediaand to add new media codes to your firmware by renaming an alreadyavailable media code. The new media code name can be entered manuallyor can be imported from the DVD Identifier media code output to be surethat no special characters are lost. This kind of media code renamingwill remove the original media code name from the patched firmware, soit is no longer supported by the firmware.
    Real adding of additional media code names would mean to shift andextend all internal media code tables or patching all media codescanner for all supported firmwares, which would be a quite complextask. So don't do it if you don't know what you are doing.
    MCSE basically hack or edit the firmware for your DVD writer and thenyou flash the hacked firmware to update your DVD writer to supportfaster read or write speed. If you don't know where to get your DVDwriter's firmware, you can head to Media CodeSpeed Edit forum to get help. Here is the link to download MCSE
    http://www.anonym.to/?http://ala42.cdfreaks.com/MCSE/MediaCodeSpeedEdit.zip
    please rate the solution if you like..
    HP DVD 1040i
    I did it...it works
    Top HP Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
