Question about Samsung Audio Players & Recorders
Radio plays for short time and shuts off ive tride every thing
When i turn on my system to play the radio it. only plays about a half-hour then the sound goes out.now heres the catch, i only can here the sound when i plung head phones in unless i shut the system down. subwoofer and all for about ten minutes. then the sound comes back ive tried the check remedy using the reset function and still no sucsess
  • Anonymous Jan 14, 2009
    HT-TX72T
  • Tammie Waddell May 20, 2013
    will it ever turn back on?
    President:
  • 624 Answers
The problem is most likely the amplifier circuit. It is probably over-heating and the speaker relay is turning off. it is not likely that it can be diagnosed properly on an online forum, since it takes some troubleshooting to be certain of it. Does this system have the amplifier built into the sub-woofer? If I had the model number I could probably give you much better advice, not all home theater systems have the exact same problems. Each different model of every brand have there own unique problems specific to that model number. There are some universal problems, but this is not one of those easy to figure out universal type of problems. I work at an authorized Samsung service center and have experience with repairing these type of systems, so if I were to get the model number I could offer you a better solution. But it is likely that it will need to be serviced to determain the exact problem. A couple of the Samsung home theater systems that have the amplifier in the sub-woofer must have the entire sub-woofer replaced because they do not offer the parts and service data needed to do a component level repair.
One way to determain if the sub-woofer has the amplifier built into it is if all the speaker wires for the sattelite speakers all connect to the sub-woofer.
Sometimes a bad speaker can cause the amp to get hot and shut down, you can check these very easy yourself.
First, while the system is turned off, disconnect one speaker. Any speaker is OK to start with. After one speaker is disconnected, turn on the system and play it at medium volume. If the system stays playing and doesn't turn off the speakers as it did before, the speaker that is disconnected is probably bad. Take it to a service center and get it checked to be certain. Most service centers will do this for free as a courtesy to their customers, it only takes a minute to check.
If the system turns off as it did with all speakers connected, you then need to reconnect that speaker and disconnect one of the other speakers and go thru the proccess again. Make sure to do all of the speaker connecting and disconnecting while the system is turned off.
If you end up disconnecting all the speakers one at a time and the system still shuts off, it could be that the sub-woofer speaker is bad or the amplifier is bad.
If you can give me the model number of your system, it would help.
Dave
Posted on Sep 13, 2008
Why does my receiver start stop producing audio output half an hour after turning it on?
Most likely is an intermittent solder connection opening up as set warms up.
May 09, 2012 | B&K CT600
THE CD PLAYER PLAY ONLY FOR HALF HOUR THEN JUST CUT OUT, LIKE A ELCTRIC ERROR SOUND, NO SOUND, BUT THE RADIO AND TAPE PLAY WITH SOUND. CAN YOU HELP PLEASE MARIANA
CD PLAYER OVERHEATING -- NOT MOUNTED RIGHT .. I HAVE SEEN THIS PROBLEM MANY TIMES AND WORSE IN SUMMER OR WHEN THE CAR HEATER TURNED ON THAT SENDS HEAT FROM UNDER THE DASHBOARD TO THE CD PLAYER ......
HAVE SOMEONE TAKE THE UNIT OUT OF THE CAR AND POWER IT UP ON A WORK BENCH. IF IT CAN PLAY FOR HOURS THEN THIS IS THE PROBLEM. IF IT ALSO STOPS PLAYING WHEN OUT OF THE CAR THEN THE LASER NEEDS CHANGING ......
Jun 20, 2011 | Car Audio & Video
05 Suzuki Forenzo Radio Problem
Display connection faulty, take apart and check connection from the display screen.
Apr 21, 2017 | 2005 Suzuki Forenza
PS3 wont work
How long were you playing it? if you were playing for a couple of hours, then it could of just overheated, in which case the ps3 will shut itself off suddenly to keep from damaging something. It should work after about half an hour, adequate time for it to cool down, if not, then you might of damaged something.
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
Sound problem
You have a shorted speaker or a speaker with a bad voice coil. This has been confirmed by the fact that the audio amplifier is shutting down (protection) but the unit stays powered on. The speakers will play for a few seconds or maybe even longer at lower volume, but any length or time or an increase in volume will immediateley shut off sound. This is due to the fact that a shorted speaker wire/connection will ground out or short to one another. If you have checked all connections behind the radio AND at the speakers and found no problems, then it is a voice coil on the speaker. A shorted voice coil will work until the speaker cone moves causing the short or until enough power passes through the voice coil's short to turn off the radio.
Solution:
1. You can use a voltmeter set to check continuity to test for a speaker short. Disconnect all speakers from the radio and connect one side of your meter to ground and the other to the speaker lead. An audible "beep" will confirm a short.
2. The other method would be to disconnect all speakers and re-connect them one by one until the radio's sound output shuts off again. This will be your shorted speaker.
I hope this information was helpful.
Apr 07, 2008 | Pioneer DEH-1800 CD Player
Car radio
Obviously there is a heating problem with it. It seems that it is getting too hot and its shutting down before it overheats and catches fire. Pull the radio out of the dash and leave the wires connected. Are there any bare wires or ones not connected good? There may be a short between the wires thats not a significant enough connection to blow the fuse. Seperate the wires from each other and turn the radio back on. Let it play till the time that it usually shuts down. If its still doing it I would suggest smashing it with a hammer.
Jan 26, 2008 | Cherokee Jeep Grand - RBB AM/FM Stereo...
System keeps shutting down
Code F61 can point to trouble in the audio output ic chip, are the loudspeakers connected correctly no short circuits.Also check that the cooling fan operates.
Sep 08, 2007 | Panasonic SC-DT310 System
Panasonic SA-HT680 DVD Home Theater Sound System
when i turn my home theater system on it says f61 then it shuts off can u plz help me out here =[
Apr 18, 2007 | Panasonic SC-HT680 System
167 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
