Question about Frigidaire FRT18B4A Top Freezer Refrigerator
Help how do you know when an defrost timer is defective
  • 943 Answers
HI thanks for your question the timer does two functions advances the fridge defrost cycle defrost the freezer for specefied minutes & go out of defrost &start to cool again I your fridge does that its ok while your working on the fridge vacuum it out THanksTHE APPLIANCE DOC
Posted on Sep 13, 2008
Bypass defrost timer
Just turn the defrost tmer clockwise to cause defrost or run conditions. If you bypass the defrost timer you will have problems like shorting of wiring or loss of the timed defrost. Why not replace the defrost timer if you know it is defective? What is the model number of your refrigerator? Thanks Sea Breeze
Jul 16, 2013 | Refrigerators
I think defrost timer frig doesnt cool enough and freezer frost up
I think you are having a defrost problem that could be related to a defective defrost timer, adaptive defrost control board, defrost heater or defrost thermostat. Can you post the model number of your refrigerator found around the fresh food section door frame? This is to insure I can point you to the correct parts. All I know is that you have a Whirlpool Refrigerator and these models all have different different parts for the defrost. Thanks Sea Breeze
Nov 20, 2012 | Whirlpool Refrigerators
Whirlpool refrigerator freezes,but not cold enough in lower part. I performed the steps to determine if its a faulty timer,defrost resistance or thermostat.If the refrigerator cycles on and off normaly,but...
Yes by advancing the defrost timer to the defrost mode and the heater not come on the defrost timer is good and it will be either the defrost heater or t-stat
When checking the defrost heater using a multimeter set to measure ohms of resistiance the defrost heater should measure to be appx 10-20 ohms if good and infinate ohms if the heater is defective
If good the defrost thermostat will be ZERO ohms...please note when checking the t-stat it MUST BE CHECKED WHEN COLD so its best to check it when frost is built up on the evaperator (freezer)coil
GENE
Oct 14, 2011 | Refrigerators
Model FF631 continues to frost up, thus requiring manual defrost by removing the ice, any ideas?
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Refrigerators
The freezer keeps freezing up, where is the defrost timer located?
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
I suggest you call a service company. your model is not listed, you may have a electronic or mechanical. defrost timer
Dec 21, 2010 | Refrigerators
Where (specifically) is the defrost timer located on my GE GSS22JEMD (Side by Side) Refrigerator? How Do I check to see if my thermostat is working or not? Please help.
The timer is controlled inside the control board on rear of your refrigerator. Four possibilities are the defrost element, defrost thermostat, Temperature CLIP EVAP THERMISTOR or the control board is defective. Let me know if you would like me to help you on this, Thanks, Sea Breeze
Jun 16, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
QUESTION ABOUT DEFROST TIMER
i'm not sure what kinda timer you have there are two, one is a timer you can cycle yourself on or off the second is a defrost board does the same-thing you just can't force a defrost with it. but the way to know if it working is (defrost timer) cycle the unit in to defrost try to hear any sizzling if so your heater and defrost t-stat are ok i would replace the timer. now on the defrost board since you can't cycle it i would check the defrost element and defrost t-stat with a meter you should read a closed circuit if the heater is good, and if the coil is frosted up you should also read a closed circuit on the t-stat again replace the board. Hope this helps you
Jan 05, 2009 | Refrigerators
My LG LRBN20514ST Fridge is not cooling
where to look for the defrost timer on the LG top freezer modle
GR-S392GCA
Aug 26, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Frigidaire FRT18B4A Top Freezer Refrigerator Logo
78 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
