Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Sansa e250 Problem
Everytime I turn on my mp3 player it keeps popping up the language section thing evertime time i turn it on and it keeps getting annoying, how could i get rid of tha? Thank you very much
  • 8,596 Answers
Use the menu button to switch menus. Here is a link to the user manual:
http://www.sandisk.com/Assets/File/Downloads/user-guides/c200-ug-eng.pdf
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
How do I reset my Sansa e250?
For resetting Sansa e250 to factory settings:
Start from Main Menu.
Next select:
Settings (image of an equalizer)
Reset All
Yes
Having problems reading the language first choose yours, select:
Language is the 5th option after Settings
Change the language to the language you prefer
Jun 20, 2010 | SanDisk Sansa e250 MP3 Player
Language problem
Hello i hope u 'll be fine.... thanks for usingfixya.
Better is that you should see from the manual guide that how can u changed the language. Try this manual guide for SanDisk Sansa e250 MP3 Player Download it and follow the steps according to it to change the language.
You can also see lots of effective information of your product from this.
  • Manual is in pdf format if you have no Adobe Reader software which support pdf files then Download it from here Adobe Reader
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Mar 09, 2010 | SanDisk Sansa e250 MP3 Player
Sansa media converter
Uninstall ALL Sansa software with the mp3 player disconnected from computer. Reinstall all software. Restart computer. Then, plug mp3 player into computer.
-Tha Mp3 Doctor
Dec 10, 2008 | SanDisk Sansa e250 MP3 Player
My e250 is stuck
sounds like it was'nt safely ejected and is damaged
Nov 09, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player starting problem
Do a Firmware upgrade first - http://www.sandisk.com/sansa/#/support-0/
Enter Sansa e200 series
If this does not work, try the other methods I suggest in my Sansa player "Tips and Tricks" - click on My Profile if you do not see the article in the solutions section (no offense to Fixya, but your website is not yet user-friendly - needs some work).
Jun 11, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Every time I go to a MP3 on my "MP3 Player" it freezes
the tip about holding the power botton for like 15 seconds works but I still cant get it to play MP3 without freezing
Mar 24, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 does not start at all
Have you tried 'recovery mode'? 1. Lock your player and hold the record button. 2. While holding the rec. button, turn on the player. You're now in recover mode. 3. Connect it to your computer and update the firmware manually. (get the file from the sandisk website and drag it into the player drive.) 4. Turn on your player and hopefully it will work.
Jul 10, 2007 | SanDisk Sansa e250 MP3 Player
Please, i need help
did you check the "hold" sliding thing on the top (where the headphones plug in)? if it's orange, slide it back.
May 03, 2007 | SanDisk Sansa e250 MP3 Player
!!!problem with my mp3 sansa e250!!!
-Tha Mp3 Doctor
Feb 22, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
you will have to go to the srichtonize thing nd right click on music and press delete then it will help you
Sep 30, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
SmartAviator
SmartAviator
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
