Question about Microsoft Windows XP Home Edition
Problem playback device
I can not hear any soung from computer after install live cam
    Guru:
  • 558 Answers
Hi Maungmaungti,
Thanks for your posting in FIXYA.
It may be some Hardware conflicts arises due to Web Cam.
Please unplug Cam from PC and reboot it.
Also check your Device Manager and use the Mobo CD from installing Sound Driver.
Regards
Ellin
Posted on Sep 13, 2008
  • Puneet Jain
    Puneet Jain Oct 17, 2008
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me
    know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
    Regards,
    Ellin
Am using a logitech cam over team viewer.my partner can see me but not hear what I say.I can hear and see her clearly.What could be the problem?
The default soundcard is not the correct on your partner's side. This needs to corrected to the soundcard of the computer.
Sometimes the applications will select a defaulted device.
This should be done in teamviewer.
Go to Options, audio conferencing, Audio playback
Select from the options another soundcard.
try again until it works.
Sep 30, 2017 | Logitech Computers & Internet
HI i install DG33bu bios update my soung is goan . please help in resting the bios version
after bios update u need latest drivers....
download the latest audio drivers from the site wer u downloaded ur bios update...
also check ur default playback device is speaker and not headphones
assuming u use windows 7
May 10, 2011 | Intel DG33BU Motherboard
How can i fix my audio suon
Method 1: Restart the computer Restart the computer at least one time after you install a Windows Vista service pack to verify that all processes related to the installation are complete.
After you restart the computer, determine whether you can hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 2. uparrow.gifBack to the top Method 2: Try another sound deviceIf it is possible, try plugging a different sound device into the computer. For example, if you were using speakers, try a different pair of speakers or a set of headphones to make sure that the problem is not related to the sound device.
Determine whether you can hear sound. If you can hear sound, there is a problem with the original sound device and the issue is resolved. If you cannot hear sound, plug the original sound device back into the computer, and then go to Method 3. uparrow.gifBack to the top Method 3: Unplug the computer speakersUnplug the computer speakers or other sound devices that you may be using, such as headphones, from the computer and then plug them back in to the same port. Most sound cards that are compatible with Windows Vista include a feature that detects sound devices plugged into the audio jack. This procedure may prompt the audio detection feature to detect and configure the sound device to make sound.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 4. uparrow.gifBack to the top Method 4: Verify that the default sound device is set correctlyAfter you install a Windows Vista service pack, you may find that the default sound device, also known as the playback device, was changed. You may also find that the sound quality has changed. Make sure that the default sound device is set correctly for the sound device that you are using. To set the default device, follow these steps:
  1. Click Start vistastartbutton.jpg, type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users, the default device is Speakers. Make sure that your audio settings are configured as expected. Follow these steps:
    1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect. When you finish, close this window to return to the previous window.
    2. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
    If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  4. Select the sound device that you want as the default sound device, and then click Set Default.
  5. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5. uparrow.gifBack to the top Method 5: Verify that a sound driver is installedWithout a sound driver, you will not hear sound. Make sure that a sound driver is installed. To do this, follow these steps:
  1. Click Start vistastartbutton.jpg, type Device Manager in the Start Search box, and then press ENTER.
  2. In the Device Manager dialog box, expand Sound, video, and game controllers.
    If there is a speaker icon next to the sound driver, the driver is installed. If there is a yellow question mark next to the sound driver, the driver is not present or will not load.
Go to method 6 to reload the current sound driver and test for sound. uparrow.gifBack to the top Method 6: Reload the current sound driver If you discovered in method 5 that the sound driver was not installed, or if you discovered that the sound driver was installed but is not working, try to reload the sound driver. To do this, follow these steps:
  3. Locate the audio device that was included with the computer.
  4. Right-click the device, and then click Properties.
  5. Click the Driver tab, and then click Uninstall.
  6. Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
  7. In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
    You receive a message that states that a hardware device is being installed, and then the uninstalled audio device appears in Device Manager.
  8. Close the Device Manager dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If the current sound driver did not reload or if it did reload, but you cannot hear sound, try method 7. uparrow.gifBack to the top Method 7: Update the current sound driver If the current sound driver does not seem to be working, see whether there is an updated sound driver that you can install. To request an updated sound driver, contact the manufacturer of the sound driver.
For information about how to contact hardware and software vendors, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors/en-usNote In some cases, the manufacturer may instruct you to uninstall the current sound driver and to delete the driver files. To do this, follow the steps in method 5, but at step 6, click to select the Delete the Driver Software for this device check box.
Dec 12, 2010 | Toshiba Satellite M35X-S114 Notebook
Why can't the other person i'm chatting with on live messenger hear me on my microsoft lifecam vx-1000 usb cam? i can hear them, and we both can see eachother. what's the problem? please helpp!
You do not give much info - for example eg, Your OS and if you have a laptop you would have 2 mics
Try setting you webcam mic as default
Vista OS
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Jul 25, 2010 | Microsoft LifeCam VX-1000 Webcam
My contacts cannot hear me. Also message comes up and says microphone is very quiet and contacts may not hear
TEST SPEAKERS
Restart computer
Configure mic to chat program
Jun 18, 2010 | Creative Labs Live! Cam Video IM Pro...
The computer says the sound driver is not proper we have lenovo 3000H error code 88780078. I want to hear good audio soungs also recharge my web camera
Please reinstall the sound driver, that'll definitely fix your problem. But firstly uninstall it from the Device Manager and restart the system, and then reinstall it. Good luck. Thanks for using FixYa.
May 29, 2010 | Computers & Internet
I just bought a live! cam voice and when i install the cd that it came with it says unable to install driver. so i went to their website and dl the driver n installed but now the problem is the mic doesnt...
Check your computer audio settings to make sure the webcam mic is set as 'default'
Plug in webcam
TEST SPEAKERS
Restart computer and configure to your chat program
Mar 18, 2010 | Creative Labs Live! Cam Voice Webcam
Audio on Dell Webcam Central And voice record isn't working
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
Aug 15, 2009 | Dell Inspiron 1545 Notebook
I have a Sound Blaster Live! Platinum 5.1...its installed properly.no evidence of problems in device manager tab...i tried the diagnostics tool and it fails the record part. i can hear the sine signal but...
Have you tried enabling the "Mic Boost" in the advanced system sound settings? Have you ensured that the Mic is not muted in the OS sound control panel? What application are you using to record? Make sure to set your app's input device to the proper card/mic. You'll find that in the Options or Preferences. You shoulds also go to the system sound settings and make sure the audio record device matches your card. If playback is your only problem, go to the system sound settings and make sure the audio playback device matches your card. Let me know if any of this helped. Good luck.
Jul 07, 2009 | Creative Technology Sound Blaster Live!...
No midi out device is detected
If you dont have a joystick port on the card, then you dont have a midi out. make sure your "out" or"playback" is patched to your card's synthesis engine, wavetable or GM/GS midi playback, and not to a "midi out" which really means a physical midi port.
Mar 01, 2008 | Creative Labs Sound Blaster Live! 5.1...
Microsoft Windows XP Home Edition Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
