Question about Sanyo DS35510 35" TV
TV won't turn on.
Been told it might be a microprocessor. What is this? Anything I can do or do I need a professional? Model number is actually one digit different is DS35520. Thanks!
    President:
  • 3,130 Answers
Its a possibility that the micro could be bad BUT most likely the standby power supply or the running power supply is bad as the regulators go bad alot in these. Also i dont know if this is one of the serial #s that the horizontal output would blow out and cause this problem because of the mounting screw came loose. If your not a tv or electronic tech, there are hundreds of volts inside this puppy ,so I would recommend that you take to a pro. Good Luck
Posted on May 16, 2006
My 2007 55' Samsung plasma will not turn on why do I need to replace power supply.
Is the TV not doing anything, or is it not making a picture, or is it turning on then turning off? Is the power LED doing anything?What is the model number? (You might find that on a sticker on the right edge of the TV) With the answers to those questions I might be able to help, although sometimes one has to actually do some troubleshooting to come to a diagnosis.
Feb 16, 2015 | Samsung Televison & Video
Need to see back of tv picture for Samsung model#ln32b36b360c5dxza dv hookup
If that was an actual model number of anything, it'd come up in a google search.
You need to first find the actual model number and add it to your question.
Feb 08, 2015 | Samsung Televison & Video
Technics SU-G91 volume control does not track when turned and +/- numbers/volume shown/heard.
Sorry. I haven't looked this model up, but I have your answer. I'm going to assume this unit is less than 10 to 15 years old. They no longer use, the type of volume control you think of. You can proof this out, by turned the knob left or right. It should probably have no stops, as you remember. That's because this is not a volume control, as in variable resistor. It is called a Rotary Encoder. It is basically two switches that are pushed when you turn the control to the left or right. This creates pulses(actually a high or a low) which go into the display microprocessor(one of the computers inside your unit). When the microprocessor control receiver this input, it controls another IC, called an Electronic Volume Control.
Sorry for the lengthy explanation. The issue lies with the Rotary Control. This is not an uncommon issue for any of the manufactures. This is not a DIY repair. It will require a professional Audio tech. If you need more assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
Nov 06, 2014 | Audio Players & Recorders
Tv turns itself on and off
in general terms it means the microprocessor in the set is locked up, you have indicated a Samsung part number but NOT a brand and model number and those are needed to know if help can be given or not.
Dec 09, 2012 | Philips Samsung HL-N5065W1X/XAA...
Ok. My volume doesn't work. This tv is less than a year old. I can't do anything with the remote, yes the batteries are fresh, and if I try to turn the volume up on the tv, it goes to the menu...
Hi I have seen this intermittent problem before in Philips sets, and what's happened is that the Button interface to the microprocessor, or indeed the microprocessor has failed, often it is the timing crystal, or ceramic resonator that controls all the timing etc, and/or dry joints in that section, it usually costs around $150.00 to fix, however without actually examining the unit, it's impossible to actually tell. So, you need to take it in to an authorised service center and ask first and only for a "Quote" and go from there once appraised of the prospective costings.It has nothing to do with the remote at all, as related it is an internal failure. Contact a Philips head or local office and ask for a referral to an authorised service center.
Oct 03, 2011 | Philips Televison & Video
MAGNAVOX 27" MODEL TS2774 POWERS
To restore your television you will need to replace the eeprom. Let me tell you why! The stereo decoder and signal processor at one time were confused with the microprocessor. This corrupted the eeprom. Without the following information, repair is next to impossible. Fortunately the repair is near..so pay attention! Location of the eeprom is IC002 on the TV board. You will need to know the numbers on the IC 001 (the microprocessor) and the numbers on IC1001 (stereo decoder). This will determine which correct eeprom to replace. The reason I say this, is there are six different eeproms to choose from. Show this info to a TV tech if you cannot do this yourself. Thanks for asking and show a few a few hands of support.
Dec 20, 2010 | Philips Magnavox 27MS343S 27" TV
I have a Sylvania 7 inch netbook SYNET07526 with windows embedded CE 6.0 and we are trying to install Microsoft Office Professional 2007 via an external hard drive without success, please help!
I've got bad news: I don't think it is possible - period. Windows CE runs on an ARM microprocessor. And you have the exact same model netbook I'm using right now. Even if you succed installing that version of Office to an external hard drive and connect that hard drive by USB, this model number of netbook simply doesn't have to computing power (or possibly the right type of microprocessor, either). If you check the Minimum Requirements on Office Pro 2007, I think you'll see that it requires and Intel or AMD microprocessor. You and I are using an ARM propcessor :( Also, I was looking into the likelyhood of expanding the memory in this machine my wife just bought. It's a cute machine' but can not do as advertised. It keeps freezing when we log into Facebook. If I can't expand the memory, this baby is going back to the store. It'll be some little kid's first computer! Good luck!
Nov 18, 2010 | Sylvania Computers & Internet
When we plug in the TV a red light comes on. When we turn it on a green light flashes a few times and then the whole TV turns itself off. We have to unplug it and plug it again to get the red light. What...
In this case it's clear that the set has engaged a "protection" mode. If there is a defect that can actually damage the your equipment further. I suggest that you take it to a repair shop for an evaluation. You will be charged for that but it's cheaper than replacing the set.
When you unplug it and wait few moments you are resetting the on board computer to the beginning of it's program. That often works if the "computer" gets confused by spikes from PG&E. Once the "computer" is reset. In this case it's warning you that it needs some professional attention. Try the place that your purchased it from for help.
This is also a good "tip" this works with anything with a microprocessor in it. Today that's like almost everything.
Zashiban
Jun 01, 2010 | Hyundai Televison & Video
Actually I have two problems: 1)my tv turns on...
I will need the model number of the TV to even begin to assist you with the problem.
May 18, 2010 | Televison & Video
My tv wont turn on. I have a toshiba regza 47hl167 and when it is in power saver mode it will not turn on have to unplug it and plug it back in till it finally comes on then change the power mode off then...
yes he is right.the digital main pcb is the brain of the tv and has the microprocessor which
controls unplugging the tv and plugging it back in.you are resetting the micriprocessor which is part of the digital pcb.
Jul 17, 2009 | Toshiba REGZA 47HL167 TV
Sanyo DS35510 35" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
