Question about Nikon D50 Digital Camera
Usb transfer is malfunctioning
When i plug the camera in to the pc the screen on the camera acts like it is aknoliging that it is plugged in to the pc and the small screen on the top says pc on on it but the computer is not getting any hardware attachment . tried mass storage device and pier to pier settings on the camera and nothing . but when i use a flash card reader all the images are there ihave tried new cables different computer. it wwas working up to one week ago i havent droped camera and have had no water or dustdamage . i would be very gratefull for any information you may have for me kind regards marcel
  • Anonymous Feb 08, 2009
    I have a Nikokn D50 digital camera. have used it for 3 years and have had great pictures. but recently went on a cruise and came back and downlouded to my daughter computer. and put on a disk with music. and the pictures are not good. the faces of people are not clear. and the water and ship pictures look like the camera is out of adjustment or something. had the camera set on auto the same as i always use. could you tel me what i might have done wrong. this was our pictures for our 50th wedding anversary and really wanted them to turn out.
  • 513 Answers
If you recently installed Real Player 10, this is the likely culprit. You will have to uninstall it and maybe do something else as described below. Real Player is aware of the problem and a fix is on the way. Several ways to download your pictures, from your camera or card reader. Before you connect your camera to your computer, make sure you have enough battery power or better yet use your AC connector if your camera came with one. Then, check your camera manual. With most cameras you simply power them on and set them to take pictures, with some you need to set them to something like connect to PC or set PTP. After connecting, power the camera and wait about 15-20 seconds for XP to recognize the camera. If it does not recognize it the connection with the USB port is not correct. To repair your USB connection: Go to Control panel>Performance and maintenance>System>Hardware>Device manager>Universal Serial Bus Controller, click on the + sign to see the list of installed devices. If your camera is connected, it should be listed there with a yellow flag (the yellow flag indicates that although the connection is there, it is not working properly). Right click on it>Properties>Troubleshoot. See if the troubleshooter can help. If not, click on Action on the top bar and then Uninstall. Leave your camera on and connected and reboot. XP should now recognize the camera and install it. Another possible solution. Click on Start, click on Run and type the following in the opening textbox: cmd and press the Enter key A window will open (black and white) and will display the following: C:\Documents and Settings\Your Name\ Type the following at the end of the above line after the \ Net start stisvc And press the Enter key You will get a message that service is already started (if so this does not solve the problem) or that it is starting (if so this may solve the problem). Then try connecting your camera after you close this window. To close this window, type EXIT at the end of the displayed line and press the Enter key. Yet another possible solution: Open Tweak UI if you have it. Get it if you don't. In Tweak UI, open the My Computer tab/line and click on Drives. A list of all possible drive names will appear with the ones you want to show in My Computer checked. If your removable storage/generic volume/camera drive as shown in Device Manager (mine was F:) is not checked, check it. The drive will appear in My Computer. If your drive is already checked, it's something else. Tweak UI can be downloaded from the following site: Windows XP PowerToys / free download http://tinyurl.com/36n Good luck!
Posted on May 18, 2006
I am attempting to transfer photos from my C713, but I can't power the camera on when it is plugged into the USB. I have changed the batteries and the camera will power on when the USB is disconnected...
Easy shares are set up so they won't respond when plugged in to usb. When you turn the camera on and then run the easyshare program and lastly connect the usb cable, then the pictures and video will transfer to the computer.
You can also take the SD card out of the camera and put it in your computer and transfer pictures that way as well.
Nov 10, 2010 | Kodak EasyShare C713 Digital Camera
When I hook my camera to a usb port on my HP 763 running windows xp, the nikon screen appears & shows the s4000 in the display & 93 pictures to be transfered to my C drive. When I hit start...
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 02, 2010 | Nikon Coolpix S4000 Digital Camera
Plug USB cord into computer to transfer photos..on camera screen it says mass storage and the USB is not recognized
Plug camera in any other USB port of computer as some time one particular USB port stop to recognize it.
Oct 20, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Nothing happens when i put my usb cable
common problem is that the USB plug you using is not the right one, as I have a phone that acts the same way certian plugs charge it but one of my plugs the Windows OS sees it as a new divice added to my computer and promps me to nquestion wheather I want to open the device or other options, common mistake is that not all Nextel/Verizion/alltel smart phones use the same USB to mini pin configiration same with digital camera the mini plug may work on a camera but not you smart phone
Jul 03, 2009 | LG Secret ? KF750 Cellular Phone
My camera won't be recognized when it's hooked up...
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
May 17, 2009 | Olympus FE3010 Digital Camera
Problem transferring photos from my digital camera to my PC
Be sure that you plug original Olympus USB cable directly into USB port on mother board (ussualy on the back side of PC) not on the front pannel hub and not into extention USB cable.
Feb 26, 2009 | Olympus FE-370 Digital Camera
Sony DSC-W170
Your Sony Cyber-Shot DSC-W170 came with a cord that had a little flat plug on one end and three separate plugs on the other end.  The single plug goes into the bottom of your camera.  The end that has three plugs has
(1) USB
(2) video output
(3) audio output
(2 and 3 are for hooking up to your TV)
If you connect the USB end to your PC and the single, flat plug into your camera, this acts as the USB cable.  There is no USB plug on the camera (for just a USB cord).
Feb 23, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Busy signal when trying to import images to my pc
I have had the same problem with getting a busy signal after plugging in the USB cord. Usually turning it on and off a few times, giving it a few seconds in between, works for me.
Also, have you tried just going into My Computer and clicking on the drive for the USB you've got you're camera plugged into and transferring the photos onto your pc from there? They only go onto your pc, not into a program but you can get them into one from there.
Dec 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Transfer Problem
What did your PC screen say? It is the PC that does the file transfer not the camera. If you use a Window XP OS, a window on the PC screen should pop up and ask you what you want to do. If you don't see that (plug and unplug the USB cable again and/or use your window window explorer (right click on the start icon and choose explore) to look for your camera. I don't have a Finepix S304, may be the camera screen just telling you that it detected a PC hook up to the camera. Good luck, Hope this help.
Sep 12, 2005 | Fuji FinePix S304 Digital Camera
Nikon D50 Digital Camera Logo
201 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
