Question about Lands Phones
RCA 25204 - Line 2 red light
My line 2 button keeps flashing red. Is there something wrong with the phone?
It probably means that you only have one line attached to your phone. Either the wall jack is only enabled for one line, or your phone cord is a two-wire cord and should be replaced.
Posted on Jan 26, 2009
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Lee
Jun 17, 2008 | GE RCA 4-Line Speakerphone
I am trying to setup voice mail on a RCA ViSYS 2-Line Phone (25255RE2), and i cannot figure it out.
Here's the manual for your 2-line phone:
http://www.rca4business.com/products/pc/pdf/instruction-book/25255RE2.pdf
refer to pages 40-43 of your manual for "Answering System Operation."
To enable your Answering System, press and hold the "ans sys" button for 2 seconds.
The "ans sys" button indicator will flash.
To disable your Answering System, press and hold the same button for 2 seconds.
The "ans sys" button indicator will go off.
May 16, 2011 | RCA ViSYS 2-Line Speakerphone
The intercom button keeps flashing red and green and it will not let us use it. It says Error: Inhibited
If you have more than one phone then its probably flashing because the phone ID is the same as another phone on your system or not setup up yet with an ID just has two dashes (--). or you if you have more than one phone on the system and have more than 2 lines coming into the phone, they all have to be on line 1 together in the first port on the back. Communication between sets are done on line 1
Oct 01, 2010 | RCA 25413RE3 Corded Phone
We are a small company and we use the rca 4-line Intercom Speakerphones. Out of 4 phones one has the intercom button that continously flashing blue and red and the intercom does not work. The other 3...
The phone may have the same extension as another phone in the system. Unplug it from the power and take out the battery for a minute. Then plug it back in. It should take a moment to find other phones on the system and assign itself an extension number.
You may also have a line reversed on that phone. Check to see if line 1 is line 1 on all of the phones. Then line 2, 3 & 4.
Another thing to check is the DSL filter. That phone may need a filter on the line to keep your DSL from interferring. If it has one replace it.
May 21, 2010 | RCA 25423RE1 Phone
Line 2 stays lit with red light
I think that just means that you do not have a 2-line connection to the phone. Either your cord is a 1-line cord or your 2-line cord is plugged into the wrong jack on the back of the phone,
Apr 14, 2009 | RCA 25202RE3 Corded Phone
Line 2 button light blinking, can't clear (and I have no line 2?)
Ok, i just figured this out a few min after posting the similar question. Reconnect your phone line to the data port and reselect the line one or line two selector swith position until the light goes out. I removed the phone from the wall to paint an must have accidently moved the switch. If the switch and the input port are out of sync you will get a red light on line one or two. Good luck!
Mar 13, 2009 | RCA ViSYS 2-Line Speakerphone
RCA Model 25204 2 line speakerphone corded with call waiting caller ID
As bsmither said, how voice mail is accessed is very dependent on your phone company and how they've set things up. They would be the best place to ask about any problems you're having there.
As for programming the voice mail buttons on the 25204, I was confused by that one as well until I finally figured it out. Specializations aside, they're just speed dial buttons, and are programmed in exactly the same way as the ones along the right side of the phone. RCA could have documented that detail better than they did.
In my case, with Vonage, I just programmed the buttons with the numbers for the lines that they're associated with. When they dial and I'm connected to the voice mail system, I'm prompted for my VM password, which I then enter manually.
Jan 30, 2008 | RCA 25414RE3 Corded Phone
Lands Phones Logo
253 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
