Question about Kenmore 64742 Electric Dryer
Kemore Dryer / Model # 63742
Heating element had been hard wired to by pass sensors. one on top one on bottom. need wiring diagram to connect sensors. Can not find manual.
  • 641 Answers
I'm not familiar with this specific Dryer, but in most of them you can find their wiring diagram glued under the upper panel or the rear panel. Good luck !
Posted on May 16, 2006
Replaced igniter and still does not heat
Posted on Jan 08, 2007
I put rugs in my dryer to fluff them up. I came back in about 30 minutes to put in more clothes to dry and the dryer was off. I pushed the start button and it didn;t do anything. I checked the breaker and unplugged the the main cord out of the wall and plug it back in hoping that would help. I don;t know what is wrong. Could you please send me a manual or a description on the wiring or something to help me. Thanks Nancy Herald
Posted on Nov 14, 2006
Need diagram for wires that hook up to heating element on fridgeidaire model LAQE 7011KWO Dryer
Hello. There are black and yellow wires that connect to the heating element. The black comes from the inlet thermal limiter fuse, the yellow comes from the main drive motor. There is always 120 volts at the element. When the dryer is initiated, the motor, using a centrifugal switch, connects another 120v supply across the other side of the element which totals 240 volts and causes the element to heat. This is done intentionally as a safety feature--the element can't heat if the motor isn't running.
Aug 18, 2015 | Frigidaire Dryers
My dv210ae dryer runs but won' heat
It's likely your heating element has overheated and the ni-chrome heater wire has been severed. There are other potential root causes, but this is most likely the root cause. There are two temperature sensors in the heating element sub-assembly, one or both or which may have failed.
The most likely cause of heating element overheating is a clogged vent. To avoid future overheating, check the vent regularly and remove any lint build-up.
The heating element, the heating element sub-assembly, and the entire galvanized metal heating sub-assembly (which includes the two temperature sensors) are available for purchase. Here are examples of all three:
http://www.ebay.com/itm/DC47-00019A-DC97-14486A-Restring-Samsung-Maytag-Dryer-Heater-Heating-Element-/271500121399?pt=LH_DefaultDomain_0&hash=item3f36ab1537
http://www.ebay.com/itm/DC47-00019A-Dryer-Heating-Heater-for-Samsung-PS2038533-AP4201899-Maytag-35001247-/161300972816?pt=LH_DefaultDomain_0&hash=item258e498510
http://www.ebay.com/itm/Samsung-DC97-14486A-Dryer-Heater-Duct-Assembly-/231215083866?pt=LH_DefaultDomain_0&hash=item35d57e315a
Before purchasing any component, verify model and part numbers match your dryer.
Before starting your repair, make sure the dryer is disconnected from its electrical source either by unplugging it or turning off its breaker. The dryer is heavy, so be careful lifting. Parts inside the dryer may be sharp to the touch, so be careful reaching inside. Use of gloves is recommended.
The heating sub-assembly is accessible from the front, behind the door sub-assembly, but may need to be removed from the rear. Follow this YouTube example-- it should be similar to your dryer even though it may not be exactly your model. Be sure to notice wires and cable connections, and be sure to reassemble just as you disconnected. It's wise to take photos as you go so that you can recall how parts and wires go back together.
http://www.youtube.com/watch?v=jbprl46J-yE
If the heating element is severed, obviously it will need to be replaced. If the mounting insulators are in good shape, you might choose to just replace the wire. As in this video, some skill is needed to disassemble the heating wire from the mounting plate. If one or more insulators have been damaged, the entire heating wire sub-assembly should be replaced. Or, as listed above, the entire sub-assembly can be purchased, which includes the two temperature sensors. This will simplify the project (but cost a bit more). The temperature sensors should be in normally-on condition, going to open state at temperature set limit. You can check the sensors with an ohm meter. If either is open at room temperature, that sensor has failed and also needs to be replaced.
Make the repairs warranted by your investigation, re-assemble the heating sub-assembly being careful to match photos you've taken, re-install in the dryer, re-assemble the dryer vent, door and top, re-connect the dryer to its electrical source, then test the dryer. The temperature should quickly rise within the dryer drum.
Apr 01, 2014 | Samsung DV210AEW Sensor Dry Electric Dryer...
I have a Bosch nextt 500 series dryer and after 2 years of use the problem I have is the heat will shut off and the dryer will keep running and I have to press the reset button on the backside of the dryer
Open the front panel, remove heat exchanger and clean. also clean out lint tray. this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Feb 01, 2011 | Bosch Axxis WTL 5410 Electric Dryer
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
I have a Bosch WTL5410 dryer, which has no heat going to the otherwise functioning tumbler. Do you know where I could purchase another heating element and where I can get instructions regarding the...
Open front panel, remove heat exchanger and clean.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the switch. This is your reset button. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Mar 24, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Have just bought a new heater element for a CL432AV White Knight Duel Heat Tumble Drier it will not heat think I have wired it up wrong do not have a wiring diagram can you help.
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Feb 12, 2010 | Dryers
Kenmore dryer not heating during cycle, what do I do?
You'll need to check the thermostats and heating element. The dryer has like two or three thermostats: two that operate the heating element, and one that burns out like a fuse if it gets too hot. Pick up a electric multimeter. I got mine at wal-mart for $5. Put it on the resistance (greek letter omega or upside down horseshoe symbol). 1X or 10X or anything doesn't matter. When you touch the probes together the needle should jump, indicating that there's very low resistance there because the probes don't resist electricity flowing them. You can use this to test the components. Unplug the dryer for God's sake, and then try to take off the back panel. If you don't see a way you can probably "pop" the top of the dryer by prying it up with a putty knife in the seam between the sides and top of the dryer. Now remove the back, and find the heating element assembly, probably on the lower right. There will be two or three wires connected to the element assembly. Two 220v wires(probably red) will supply power to the element and one control wire(probably yellow) send feedback to the controller. Check the resistance of the heating element and each of the thermostats by putting the probes on the wires on each "side" of it and check the resistance. If something has a very high resistance on the high voltage wires, it's probably defunct and needs to be replaced. The yellow or control wire might have a resistor on it that your meter would read as bad, but you're only concerned with the high voltage supply wires. Note that the wiring diagram will probably be hidden somewhere inside the dryer when you open it up. If all the parts in the element assembly check out ok follow the wire connected from the element to the motor and check the resistance of the resistors and stuff on the diagram. Note that is a resistor have a value like 10k(10,000 ohms) you may have your meter set too low for the needle to actually read it. That's what the 1X, 10X multiplier settings are for if your meter has them. Other problems could be a loose wire, dirty moisture sensor inside the drum, defective controller, or defective switches.
Oct 23, 2009 | Kenmore Dryers
Kemore dryer model 65862 not heating. Replaced the heating element and verified that the thermastat is getting continuity.
do you have both power phases as in 120 volts per leg? also check your neutral wire at the dryer element if it uses one, they carry the im-balance of current and get brittle with age and break at the heating terminal connection
Oct 02, 2009 | Dryers
JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
May 25, 2008 | GE JBP66 Electric Kitchen Range
Kenmore 64742 Electric Dryer Logo
537 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
