A
Anonymous Posted on Sep 06, 2011
I brought a apple component av cable and have sound but no picture i have tried restarting my device but it is still not working
SIMON MATTHIAS NG
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 58 Answers
  • Posted on Sep 07, 2011
SIMON MATTHIAS NG
Contributor
Level 1:
New Friend:
Cheetah:
Answers
58
Questions
0
Helped
24023
Points
75
Are you sure you buy the right certified original apple av cable that suits for your particular apple model? There's a lot of compatible brands AV cable which claimed they are compatible. But unfortunately they are not. I would suggest you to contact your local authorised apple shop to check your AV cable whether it is really compatible or not.
I have an onn 42 inck flatscreen tv and since last night have lost all colour on screen,,,tried cable and scart all seem ok,,any ideas
Hi.
If the problem happens using different input and devices, then it is either the terminal circuit (input/output connectors) or the processing unit in main board. The terminals are unlikely the culprit if problem concerns different inputs.
I imagine that the picture is not properly B&W (gray-shades) but some kind of reddish, bluish or greenish picture as the LCD will process picture using RGB (red green blue) channels instead of CYMK (cyan yellow magenta black) like CRT TVs.
Test the TV using an external aerial. You will notice if the channels have the wrong color even from static.
Use different inputs, different cables and different devices. beware of SCART cables, the SCART contacts are very easy to break. A defective cable will loose picture. Better testing using AV cables and component cables. AV cables are red/white for sound and yellow for video. If the two-wired yellow cable does not work, then the TV is faulty.
Other test can be done using component cables. Component cables send the three red-green-blue signals on different cables, hence testing is simple. Test swapping cables and see if TV tone stays the same if color tone changes the problem were the cables. Test also using at least two different devices (e.g. one DVD player and one TV receiver or a playstation).
If you find that the TV is defective call the manufacturer at the number listed on manual. If the problem is that one or more RGB channels do not work the TV main controller board must be replaced.
Regards.
Ginko
tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
I have purchased the apple component tv cable for my ipod 5th generation but when playing back videos I have only sound - no picture. I have set the Ipod to tv out, PAL (Aust) & connected all the...
Hi, this seems to be a physical failure with your connections and not your TV input configuration (as you're able to listen to your audio). First, try to see if there's an obstruction on your iPod dock (maybe some dirt or dust) and on your AV cable. As the video travels through different pins than the USB or power, you may've not noticed the failure until now. Sony Bravia TVs are all built in the same factory, so they can easily change from NTSC and PAL, try going to your settings and change the TV out to NTSC. If everything else fails, take it to your Apple Store, they'll be more than happy to test it for you and if it's broken, replace it for a working one.
--Dennis
1helpful
2answers
No sound, picture ok, volume nil
What cable u are using?Like a RCA AV component cable or a HDMI cable?Tries another AV holes in the tv,if use a HDMI cable tries another HDMI hub on the tv.Or replaced with it the new RCA AV component cable or a HDMI cable.
Sony KV-32FS12 Component Video 4 Has A Wavy Picture
sounds to me like the differnence between watchiing in progressive and interlace. these older tube tv's are not capable of displaying a progressive scanned image. like the first dvd players. check your video out settings on your ipod to make sure its an interlace output.
I have video but no sound using component av cables
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
The main reason why its acting that way its possible that the AV PORT is faulty or its your cables..
2helpful
No color from iphone to tv
that is because the resolution of your TV doesnt match the resolution of the movie file. try to play it another tv with higher resolution
1helpful
How to connect the apple component av cable to panasonic tv
you may need to check you display setting on your flat screen to see if it set to 480p. You may be sending to low of a resolution from the phone to the TV
2answers
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
 Grubhead
Grubhead
SmartAviator
SmartAviator
