Question about Sony KP-53S65 53" Rear Projection Television
Blue convergeance I can't adjust the blue convergeance on my Sony KP-53S65. The red adjust OK but not the blue. Can someone help me with this.
  • Timothy Peacy
    Timothy Peacy Sep 13, 2008
    I can solder and use a meter. I do have some electronics training. I work for a living fixing computers and accessories but, I don't do it a component level. Also, I don't know TV's all so well. I do digital electronics mostly.
    Novelist:
    Champion:
  • 203 Answers
Can you use a meter and solder? If you I can help you fix it. If not you will need to call a repairman. let me know what you would like to do!
Tim Nolan
Posted on Sep 13, 2008
  • experttv
    experttv Sep 13, 2008
    The components that need changing are relatively simple to do. If you call a repairman to do it he will most likely charge $300-$500 if you need further information let me know!
    Tim Nolan
Sony kp-ws500 has very fine red and blue horizontal lines across screen tried adjusting convergence, and it didn't do anything
Red and Blue Tube screen drive controls needs to be turned down some, tubes are over driving causeing drive lines.
Sep 16, 2010 | Sony KP-65WS500 65" Rear Projection...
Sony rear video projector.KP-53S65. Turned on the TV today and has a double image and the colors are off. No previous malfunction. Any suggestions?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest a shop.
Jul 03, 2010 | Sony KP-53S65 53" Rear Projection...
I am having issues with my Sony KP-53s65 53in TV... You see double people and words. The color is off and the focus setting does not correct this issue. The RED and BLUE cross bars are lined up with the...
you need to get into the service menu on the tv and adjust some values you can find these values online but i would highly recomend that you get a service centre to look in to this ,
i've done mine my self but if you hit the wrong valuye you could mess the whole tv up there are about three pages full.
hope this helps
Jul 05, 2009 | Sony KP-53S65 53" Rear Projection...
Tearing Blue streak from top left.
The convergence amplifier responsible for blue is dying. Soon blue will be off all over the screen when it fails completely. Only solution is to have the convergence output IC's replaced.
May 27, 2009 | Sony KP-53S65 53" Rear Projection...
KP-53S65 Blue Ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 11, 2008 | Sony KP-53S65 53" Rear Projection...
SONY KP-61XBR38
it could be either convergence or the velocity boards. Are you able to move the red and blue convergence in all four direcctions with the convergence adjustments?
Jul 12, 2008 | Sony KP-61XBR48 61" Rear Projection...
Double vision
Convergence ICs are bad it causes the red and/or blue to jump out of alignment making it look 3D. You have to convergence ICs located on a large aluminum heat sink with an STK number stamped on them. You can purchase new ones for about 10.00 each. they have to be soldered in. If you can solder you should easily be able to repair this yourself. Let me know if you need anything further.
Jan 24, 2008 | Sony KP-53S65 53" Rear Projection...
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
Blue Ghost
You need new convergence ICs . They cost about 10.00 each you will need two. They are located on a large aluminum heat sink with an STK number stamped on them. They will have to be soldered in. If you can solder you will be able to do this repair yourself. Let me know if you need ay additional Info.
Nov 14, 2007 | Sony KP-53S65 53" Rear Projection...
Poor color issues.
try adjusting the convergence. good luck and happy valentine!
Feb 14, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
