I'm trying to connect to remote desktop but it says my server is too busy,or network problems might be the problem
    Scholar:
  • 94 Answers
You could check the firewall on your computer and the computer that you want to access,
sometimes anti virus could interfere with this also.
Posted on Sep 13, 2008
3crevf100-73
Configure the 3COM to direct all incoming 3389/TCP traffic to 3389/TCP on the "private" IP-address (192.168.xx.yy) of your server.
Configure your server to "allow" Remote Desktop connections, and add the ID/password details that will be allowed to login to your server.
Apr 23, 2014 | 3Com OfficeConnect (3CREVF100-73-ME)...
Network Error (tcp_error) A communication error occurred: "" The Web Server may be down, too busy, or experiencing other problems preventing it from responding to requests. You may wish...
This can be :
1-Your ISP has connection problems or connection speed is slow
2-The server you try to reach is busy at that time.
3-Or if you are under a network,the network itself is having connection issues.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 13, 2010 | Facebook Social Network
Error code 651
Error code 651
This error corresponds to an error in a modem or any other connecting device
Try the folloging the instructions below:
If this is a dial-up connection, and you are using a supported external modem, turn off and then restart the modem. Close and restart Network and Dial-up Connections, and then redial. If the problem persists, try connecting at a lower initial speed. See To change the maximum modem port speed. Make sure you correctly configured your modem for remote access. To check your configuration, see To configure a connection. If this is a virtual private network (VPN) connection, you might have specified an incorrect TCP/IP address in the connection configuration, or the server that you are trying to reach might not be available. To determine if the server is available, see your system administrator.
Oct 18, 2010 | Computers & Internet
How do i connect this terminal to windows 2003 server please give me the settings
Open Remote Desktop Connection loadTOCNode(2, 'summary'); To open Remote Desktop Connection, click Start, point to All Programs, point to Accessories, point to Communications, and then click Remote Desktop Connection.
Create a Terminal Services Connection loadTOCNode(2, 'summary'); To create a Terminal Services connection, follow these steps:
  1. Open Remote Desktop Connection.
  2. In the Computer box, type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
    Note: To connect to the console session of the remote computer, type computername or IP address /console.
  3. Click Connect.
  4. In the Log On to Windows dialog box, type your user name, password, and domain (if necessary), and then click OK.
Save Connection Settings loadTOCNode(2, 'summary'); You can save a connection as a Remote Desktop protocol (.rdp) file. An .rdp file contains all the information for a connection to a terminal server, including the Options settings that were configured when the file was saved. You can customize any number of .rdp files, including files for connecting to the same server with different settings. For example, you can save a file that connects to MyServer in full screen mode and another file that connects to the same computer in 800×600 screen size.
To save your connection settings, follow these steps:
  1. Open Remote Desktop Connection, and then click Options.
  2. Specify the connection settings that you want for this connection.
  3. On the General tab, click Save As.
  4. In the File name box, type a file name for the saved connection file, and then click Save.
Note: To edit an .rdp file to change the connections settings it contains, click Start, click My Documents, right-click the file and then click Edit.
Open a Saved Connection loadTOCNode(2, 'summary'); To open a saved connection, follow these steps:
  1. Open Remote Desktop Connection, and then click Open.
  2. Double-click the .rdp file for the connection that you want to open.
Copy Files Between the Local Computer and the Remote Computer loadTOCNode(2, 'summary');
  2. Type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
  3. Click the Local Resources tab, select the Disk Drives check box, and then click Connect.
  4. Click Start on the task bar of the remote computer, and then click My Computer, or double-click the My Computer icon on the desktop of the remote computer.
    Note: The drives on the remote server appear with the drives on your local computer. Your local drives appear as driveletter on tsclient, where tsclient is the name assigned to your (local) computer.
  5. Locate the file that you want to copy, right-click the file, and then click Copy.
  6. Locate the folder where you want to paste the file, and then click Paste.
Log Off and End the Session loadTOCNode(2, 'summary'); To log off and end a session, follow these steps:
  1. In the Remote Desktop Connection window, click Start, and then click Shut Down.
  2. In the Shut Down Windows dialog box, click Log Off username, and then click OK.
Thankyou
Amit Bhardwaj
Skype Id:- amit.bhardwaj4
May 05, 2010 | VXL Instruments Itona CE Windows CE VIA...
Cannot detect other printer in remote desktop connection
Hello my friend, regarding on your problem kindly check your system particularly your windows 2008 server OS. Kind reinstall the printer drivers then then shared it. Then after you share the printers kindly check the ip address of your windows server 2008 OS then go to the workstation Computer then click start button found in your task bar manager then click run. Then kindly type the "\\IP of your windows server 2008" where your printer drivers installed then enter. As soon as you can log in the Windows server 2008 menu environment then if you can find or see the printer icon then click the printers icon then right click then click connect. Let the system automatically installed the printer driver to your workstation computer. then as soon as your system finished installed the printer drivers then try to run and print if you can now print using network LAN.
Hope this solution able to solve your problem. If you need more assistance kindly rely to this post.
Thank you.
geo_jonas
Jul 17, 2009 | Office Equipment & Supplies
SIte to site vpn/remote desktop
Open up the vpn client any any of the working machine, and then
click on
file>>save Prfoile>>give a name
Take a copy of that and paste it in your machine.
On your machine install the vpn client (Straight Forward Installation). Then
Click on Import Profile , Identify the location where you have pasted the profile (Which is copied from other machine).
You are done with that.
Mar 13, 2009 | Cisco PIX 501 Firewall
Im face the some problem in hp dx7400 pc.i have
You can install Windows XP professional's network driver for windows server 2003.
To download the desire driver CLICK HERE
Thanks
Feb 24, 2009 | HP Compaq Business Desktop dx7400 - Core 2...
SHOWINGH CANNOT FIND SERVER
server u tryed to open is busy or ur network is busy,retry it if the problem exists,then the sever is busy.try to connect after some times
Aug 15, 2008 | Computers & Internet
Windows Vista home + Windows XP Professional Networking issue
Make sure domain settings to your server are correct on the notebook computer. These settings are located in the control panel of the system setting.
Whats the operating system of your server?
Make sure the firewall in windows security is turned off too. Sometimes that thing sneaks up on you.
I haven't used the home edition of Vista but another reason why it might not be working is because it isn't the business version. Microsoft might have added extra security to prevent the home version from connecting to a server. I know we use the business version of Vista at work and it is working that way on the intranet server without a problem.
I would check with Microsofts website on that.
Jun 21, 2008 | Microsoft Windows XP Professional for PC
Parker Vision Router WR1500
You need to forward the remote desktop port to your server. The Remote Desktop port is 3389. Go to the port forwarding section of your router and find out your Server's network IP address and assign it to forward the Remote Desktop port of "3389". Save your changes and try connecting again.
Sep 06, 2007 | ParkerVision SIGNALMAX WR1500...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
