Question about NetGear DG834G Router
Problems with the NetGear DG834G Router.
I think I can help you with your issue.
I just the following info from you so that I can help you better.
- When you say the internet light off or is flickering, do you mean the sync light which kinda looks like an i with a semicircle below it?
- What is the status of the Diagnostics light?(its the the light which has the tick or the correct sign symbol).
- Who is your ISP?
- What is the connection type?( ADSL- IP/data stream, LLU- MPF/SMPF)
    Problem Solver:
Provider is A.O.L. connection is:adsl.via a router ,I have also noted that my upload speeds are higher than my download speeds.
Posted on Oct 29, 2008
I have just changed from a Netgear DG834G V4 to a Netgear N150 (Supplied by Orange) Router and the signal is now virtually non existant in parts of the house (upstairs and further away downstairs rooms)...
Netgears products are terrible with non support what so ever. I'm sure you had change your router already, but if your ISP could provide you with a different brand, the problem will disappear.
Mar 30, 2015 | NetGear DG834G Router
Netgear router reset
You can reset your Netgear router/wireless DG834G router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless DG834G router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Feel free to get instant online Netgear router support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Feb 06, 2012 | NetGear DG834G Router
Trying Netgear wirelss N modem router .. it works prefectly in one location , but drops frequently in another location ... even if the handheld is next to the netgear.. why does this happen ?
please follow steps which can fix you issue
1.open router login page
2.changed channel number into 11
3.upgrade firmware on router
regards
prakash
Jan 26, 2010 | NetGear DG834G Router
NETGEAR wireless ADSL firewall router DG834G how to set port, coz i think my router just blocked UDP 6100..and i cant use my VENT...pls help
go to the router then go to the nat option then go to the port give ur port number 6100 and give the udp and tcp both
Mar 27, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Netgear DG834G V4 Website connection problems
Please try to use a difrent DNS service.
For example open DNS:
Primary: 208.67.222.222
Secundary: 208.67.220.220
Jan 14, 2009 | NetGear DG834G Router
First use the Netgear setup wizard:-
Open Internet Explorer
Enter http://routeraddress e.g http://192.168.0.1
Click Setup Wizard (top left)
Then for With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It should search for your connection, find it and allow you to log on.
Feb 06, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Firmware upgrade
Here you go, just select the version of your router from this page
http://kbserver.netgear.com/products/DG834G.asp
Hope that helped!
Dec 10, 2007 | NetGear DG834G Router
Netgear DG834G router
Are you getting any internet?
Are you using Windows Vista?
Oct 19, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Netgear dg834g
well have you set the router up correctly with your isp connection. what i mean is have you goneinto the settings of the router and input the info for your type of connection, username, password, etc. it sounds like you haven't done that to me. if you need more info or can give me more info then i can help you. let me know.
Sep 19, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
184 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
