Question about Maytag Kitchen Ranges
All of a sudden, none of the 4 elctric starter on the burners work on my maytag gas stove
    Sergeant:
  • 409 Answers
Sounds like the spark module is defective. have a technician replace it.
Posted on Sep 13, 2008
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
2 of the 4 burners on my maytag gas stove aren't working. the oven is fine, just need to know where to light the pilot
Most newer Ranges don't have a pilot ... they have an electronic ignighter. When you first turn the burner on ...you hear the spark going crack,crack
Feb 20, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
MODEL MGC543OBDS GAS STOVE THE ELECTRONIC STARTERS ALL FIRE WHEN TRYING TURN JUST ONE ON..
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 29, 2010 | Maytag MGC5430 Gas Cooktop
None of my 4 ignitors will spark
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Oct 25, 2009 | Maytag MGS5870 Gas Kitchen Range
Maytag Gemini gas stove top ... while starting one of the front burners, the starter knob in the back started on fire. Help!!
You have a gas leak which resulted in the unwanted fire. This has the potential to be serious or deadly. This is one time when you need to get a pro in there to stop this leak and get your stove safe again.
Jun 16, 2009 | Maytag MGR6775A Gas Kitchen Range
One burner will not turn on - This is a Maytag Precision Touch control 500 electric smoothtop
hi there,
on this case try to clean the gas burner for any dust and corrosion inside. also check and test the ignititer of the stove/
let me know.
Jun 02, 2009 | Maytag MER5770 Electric Kitchen Range
Elect Ign not sparking, but get gas, other appliance working.
I don't know, I did nothing, it just started working again??????
Jan 28, 2009 | Maytag 30 in. CSG7000 Gas Cooktop
I have a 4 yr. old Maytag stove model #PGR5715BDQ, the burners all work fine as well as the broiler. The bake ignitor glows red and after a while gas can be smelled but burner will not light. A match will...
I have a Jenn-air stove model # JGS8750BDS in the oven when I call for bake the ignitor come on and glow then the gas come on but the burner want light but I smell the gas what is the problem
Aug 26, 2008 | Kitchen Ranges
Kitchen Ranges Logo
103 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
