Question about E-Machines eMachines Desktop PC
Wiring diagramfor w2925
Need a diagram for my computer to make sure all the wires are in the right spot computer fans turn on and the monitor says that its not connected to computer
  • dozerxxx Sep 14, 2008
    need wiring diagram for the inside of the tower not the outside
  • Anonymous Apr 26, 2009
    power switch wont turn off computer. need wiring diagramfor inside tower
  • 4 Answers
Here's a link to emachines' webpage with the user's guide in pdf format to download.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W2925
or download it directly here
http://downloads.emachines.com/userguides/DesktopPC_UserGuide_en.pdf
You must have a PDF reader installed or you can use this snapshot form its Page 19 - PC Desktop Back
The cable from your monitor must connect to the Monitor port (middle and right on picture). Be CAREFULL not to force the connection. The cable only fits one way and you can damage the pins if you force it. If it won't plug in easily, then rotate the plug 180 degrees and try again.
If your connection seems inadequate, you may have bent one of the pins. If you suspect a bent pin, look into the end of the connector on the cable to see if one or more of the gold colored pins are bent. You can straighten the pins yourself with a needle-nosed pliers or a small blade screw driver use gently, otherwise try to get a replacement monitor cable.
Posted on Sep 13, 2008
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
Wireing diagramfor sound lab g002gh smoke machen
I am sorry but fixya has no wiring diagrams.
Jul 17, 2012 | Cars & Trucks
Got db156 given to me need a wiring diagramfor it
Most units basically have the same wiring....this is the wiring for my sons Clarion:
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
Jun 29, 2011 | Clarion Car Audio & Video
Need wiring connection diagram for Power Switch to Motherboard for EMachine W2925 model. Wires were disconected accidentally while cleaning inside of tower
micha219, the eMachines W2925 desktop computer uses an FIC motherboard.
First International Computer { Inc }
The Model Number of the FIC motherboard is VC37.
FIC VC37.
Disregard the following if you are aware:
The plastic front of your computer is the Front Panel.
The area on the Motherboard that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Processor to the Top, Ram Memory slots to the Right, the Front panel header is in the Bottom Right corner.
It is a rectangular shape with two columns of pins.
The length goes up, and down on the motherboard.
The pins on the Right side of the Front Panel header are numbered Odd.
The pins on the Left side of the Front Panel header are numbered Even.
There are 4 pins on the Left side.
There are 5 pins on the Right side.
Starting at the Bottom on the Right side going Up;
Pins 1, 3, 5, 7, and 9.
Starting at the Bottom on the Left side going Up;
Pins 2, 4, 6, and 8.
A) Pins 2 and 4 are for the Power On LED light.
(If after connecting the LED light is dim, reverse the wires)
B) Pins 6 and 8 are for the Power On switch. (Power On button)
C) Pins 1 and 3 are for the HarDDrive Activity LED light.
D) Pins 5 and 7 are for the Reset switch. (Reset button. IF used)
Pin 9 is NC. Not connected
Oct 18, 2010 | E-Machines eMachines Desktop PC
Need a wireing diagramfor toyota camry 95 for car radio the coloers dont match the new radio wire harnest
1995 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: Black/Red
Radio Amp Trigger Wire: None
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
May 05, 2010 | Car Audio & Video
I need a wiring diagramfor the stereo on a 2001 dodge neon
Sorry to say there isnt one available (if its the factory stereo)...the only diagrams available would be for the wiring in the up to the connector at the back of the radio
Jan 12, 2010 | 2001 Dodge Neon
Wil like to print wire diagramfor 1994 capice clasic
I haven't found a source of online wiring Diagrams, but the Hayes manual usually has one in the back. Make sure to read the cover or back to see that it includes wiring diagrams before opening up the celophane.
Nov 05, 2009 | 1994 Chevrolet Caprice Classic
No monitor signal and hard drive not spinning? (eMachines T3025)
wiring diagram? Usually you just plug in the 4 pin molex connector. If its not spinning the HDD is damaged and needs to be replaced.
Also I can tell you the Wires are Yellow=12v Black=ground RED=5v and orange=3.3v
Apr 16, 2009 | E-Machines T3025 PC Desktop
Intel E139761 or AA 732604 Motherboard wiring diagram
http://www.cs.unc.edu/~jeffay/dirt/FAQ/DELL410_ServiceManual.pdf
Seems you have a Dell computer. Is this manual the right one?
Feb 06, 2009 | Intel AAVID Pentium III Dual Cooling Fan -...
E-Machines eMachines Desktop PC Logo
275 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
