Question about Microsoft Windows XP Home Edition
PC SHUTS DOWN MONITOR AND FAN
MY COMPUTER SHUTS DOWN BUT LIGHT ON TOWER IS ON AND MONITOR LIGHT ON, FAN GOES OFF. I HAVE TO TURN POWER BAR OFF AND ON. SOMETIMES IT STAYS ON SOMETIMES NOT IN THE LAST 2 DAYS ABOUT 4 TIMES PER DAY.
WINDOWS XP 2003 HOME EDITION, SAMSUNG SYNCMASTER 955DF MONITOR
NEED HELP DESPARATELY
  • 6 more comments
  • brandy19960 Sep 13, 2008
    waiting for reply any expert to help me please its getting worse shutting down.
    Please reply.
    Thanks
  • brandy19960 Sep 15, 2008
    My reply disappeared.
    So here it is again,
    Step 1 - unchecked Auto Restart
    Step 2 - computer said "not found"
    Step 3- no red x could not find it
    Step 4 - good advice will use if needed
    Step 5 - unchecked "Alllow computer to turn off"
    Step 6 - ran "misconfig" - although I am not sure what I was to do here, lots of programs checked
    Computer still shutting down 4-5 times per day since Thursday. Sometimes within a minute of turn it on and sometimes after some hours.
    Do I need a new powerbar, alhthough this does stay on.
    My outlet I use is connected to the kitchen applliances, such as microwave, could this be a problem. Although its been on this plug for 5 years without a problem?
    DON'T KNOW WHAT DO??
    HELP:
    Please note my comment of September 15, I still need some help with computer shutting down a lot.
    Does the red light on the tower stay on after start up, it does flicker, could it be that the turn off on my tower is not connection or broken?
    Getting desparate HELP?
    Good morning Ellin thanks for replying.
    I did system restore, the red light on tower is not lit up though.
    Ok, to repair windows do I just insert the disk, and follow the installation process, do I have to remove anything. Is that the only disk I need to re-install.
    Step by step instructions would help. Not much of a computer expert myself, just on some things.
    Hope to hear from you soon.
    Thanks big time for your help. I will do rating after this procedure.
    Hi ELLIN'
    So far since i did system restore it has not shut down - happy I found a good date to go back to.
    Now should I still do the windows xp install as you stated. Thank you so much for the step by step information.
    Great Job
    Thanks
  • brandy19960 Sep 18, 2008
    Good morning Ellin:
    Problem still shutting down, I tried to install Windows XP, but got a message that a newer version was installed and that my disk might corrupt files and to not install it. I am not sure but the computer repair guy that came and fixed it a month ago might have put a new version, but I don't think so, maybe its the updates from Microsoft. But I was too scared to continue the install.
    It has shut down 4 times already this morning.
    Could it be the fan or cooling system, or the on/off button not connection I don't know. What should I do now?
    Thanks Ellin
  • brandy19960 Sep 19, 2008
    Good morning Ellin computer has shut down 12 times this morning hope I can send this message b4 it shuts down again. Going to have to call a repair man in. Its going to be expensive.
    I think the fan/cooling system is shutting it down. However we shall see. I probably will go with premium after this. don't have a choice unless it stays up this time
    Thanks
  • brandy19960 Sep 23, 2008
    Good morning
    It was the power supply which has now been replaced by my son - repair guy - too expensive and my son was able to install it.
    Thanks for your help
    Guru:
  • 558 Answers
Hi Brandy19960,
Thanks for the posting in FIXYA.
Please do the following steps:
Step – 1
Right-click on My Computer, open Properties, click the Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” Uncheck the box in front of “Automatically restart.”
Step - 2
To change the setting, click Start --> Run--> type GPEDIT.MSC, click OK.
Drill down to Computer Configuration | Windows Settings | Security Settings | Local Policies | Security Options.
In the right pane, find “Shutdown: Clear Virtual Memory Pagefile.”
NOTE: Since someone actually has to have set this policy, the problem will be pretty rare, but is worth mentioning. However, Forum participant “roadrunner” reported that the personal security app Privacy Eraser automatically enables “Clear virtual memory pagefile,” and, therefore, may be the cause of a slow shutdown.
Step - 3
When Windows XP won’t powerdown automatically, the APM/NT Legacy Power Node may not be enabled. To enable this, right-click on the My Computer icon, click Properties | Hardware | Device Manager | View. Check the box labeled “Show Hidden Devices.” If it’s available on your computer, there will be a red X on the APM/NT Legacy Node. Try enabling it and see if this resolves the powerdown problem (Tip from Terri Stratton). Or, to check the other side of the APM/ACPI coin, open the Power Options applet in Control Panel. If there is an APM tab, make sure the “Enable Advanced Power Management Support” box is checked.
Step - 4
Try a Shutdown shortcut -
For a shortcut to RESTART Windows XP:
SHUTDOWN -r -t 01
For a shortcut to SHUT DOWN Windows XP:
SHUTDOWN -s -t 01
Step 5
WORK-AROUND: Disable power management for your USB hub: Open Device Manager (click Start, click Run, type DEVMGMT.MSC, click OK). Double-click to expand Universal Serial Bus Controllers. Double-click USB Root Hub. Click Power Management. Uncheck the box “Allow the computer to turn off this device to save power.” OK your way out
Step – 6
Click on the Start button.
Select Run from the menu.
In the run dialog box type “msconfig”.
Click OK.
Once in the msconfig utility select the startup tab. In the startup tab you will see several programs listed with a checkbox beside it. If there is a check mark beside the application listed, the application will startup when your computer starts up.
Regards
ELLIN
Posted on Sep 13, 2008
  • 3 more comments
  • Puneet Jain
    Puneet Jain Sep 15, 2008
    Hi Brandy19960,
    Thanks for replying.
    Your computer OS is need to repair. As you mentioned the Step 2 could not be done.
    In my opinion, you may try now :
    1. System Restore to a Good Normal Condition
    2. Repair Windows By Installation process.
    Regards
    ELLIN
  • Puneet Jain
    Hi Brandy19960,
    Thanks for your reply.
    I am not clear about System Restore operation you have done, is the problem not solved. Try to find out first the relevant date to which your PC working normal.
    And step by steps Repair method for Window XP is given as:
    • Insert your Windows XP CD, If the bios is set up with Boot with CD, then during reboot it will soon
      show "Press any key to boot of CD" will appear on the screen, hit the space
      bar to continue.
    • Now setup will inspect your hardware
      and software, it then will load various files required for the repair. Just wait
      and be patient.
    • Soon a menu will appear, press enter to continue.
    • Now the "End User
      Agreement" Press "F8" if you agree, "ESC" if you don't.
    • It will also ask for enter your Serial key of the product, so provide it.
    • You will now have get the
      installation or repair. Use the up/down arrow key to select the install, and then press "R" to
      continue.
    • Setup will now examine the disk be
      patient, it can take a few minutes.
    • Setup will go through a percentage -
      1 to 100%
    • A screen will soon appear. Press
      "F3" to continue
    • Now setup will reboot system, wait
      15 seconds or just press enter.
    • Now it is time to see if this has
      solved your problems.
    Regards
    ELLIN
  • Puneet Jain
    Puneet Jain Sep 17, 2008
    Thanks for your cooperation.
    I think in future if you need any assistance will not forget the Fixya services.
    Regards
    ELLIN
  • Puneet Jain
    Puneet Jain Sep 18, 2008
    Hi Brandy19960,
    CD is unable to install windows due to the updates from Microsoft.
    Your system now needs complete analysis for which I must recommend you to come for Premium services provided by Fixya.
    So I am waiting for you to start a Live session as soon as possible.
    Regards
    ELLIN
  • Puneet Jain
    Puneet Jain Sep 19, 2008
    Thanks for the information provided.
    I hope the Hardware engineer must resolve the case and advise you in better way.
    Since he has the opportunity to repair PC manually.
    Regards
    ELLIN
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
ask.
tower PSU, 101
http://pcdied.com/power.html
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
I turned off the computer by going to shut down earlier today I went to turn it back on this evening and the CPU won't turn on
hello, make sure nothing has come unplugged and that none of the buttons are stuck on. With that said if this is an older pc, your power supply inside the case might have went out. power supplies go out quite often, replacing them is not to bad just make sure you have the correct physical and power size. Also verify that it has the connectors for that particular motherboard.
hope this helps
Jan 14, 2011 | HP Pavilion a6650f Desktop PC
Describe your dell dimension E521 wont boot and Problem my computer turns on but doesn't open it goes to a black screen with little flashing bar in top left corner nothing new was installed but there...
The 123 lights on tower translates as:
Routine system activity subsequent to video initialization.
Watch your monitor for on-screen messages.
Disconnect the video cable from the computer and see if you get floating color bars on display. If not, your monitor is defective.
Jan 10, 2011 | Dell Dimension E521 PC Desktop
I have a Dell Dimension 4600. I press the power button. The left light on the tower turns on amber, the right light comes on for 15 seconds or so then shuts off. The monitor will not come on, but will...
The most likely cause is a failing power supply. Unless you have a tester you will need to buy a replacement. Check the specs and order a suitable replacement. (www.newegg.com is my choice)
If any of this goes past your computer knowledge take your computer to an expert to examine first-hand.
Dec 26, 2010 | Dell Dimension 4600 PC Desktop
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
My tower has power but won't come on
first guess is the motherboard is bad
a few things you can try:
unhook the monitor from the computer and test it on another computer. If the monitor works then its most likely the motherboard.
leave the computer unplugged for a few hours then plug it back up and give it another try just in case it overheated.
have the computers power supply tested as a bad power supply can cause all sorts of issues.
other than that you are down to a new motherboard and or a new computer.
Sep 09, 2009 | Compaq Computers & Internet
Yellow power light on HP SR1420NX
For reasons yet to be determined, your computer is not talking to your monitor.
This could be the monitor cable came loose from the tower (this is our favorite, because it is such an easy repair), or something on the motherboard (that is, anything) that is not functioning and preventing your computer from starting.
Unplug the connecting cable, and plug it back in again, making sure that it is seated properly.
Do you hear any sounds besides the fans? You should be able to hear the faint clicking of a hard drive starting up also. If you hear this, the problem is not in the computer, but in the communication to the monitor.
Good luck
tony
May 23, 2009 | HP Compaq Presario SR1420nx...
Computer shutting down
do you get a blue screen when it shuts off? or... does the monitor just turn off, or does the computer tower and everything turn off?
If everything turns off,(like a normal shutdown) try checking your power options in the control panel, to make sure there aren't some power saving settings that are causing it.
If its a blue screen type issue, then there may be a hardware problem that is causing the computer to shutdown to avoid further damage to the system.
Jun 27, 2008 | Acer Aspire T120 PC Desktop
Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Jun 02, 2008 | Gateway GT5404 PC Desktop
LG L1751S Flatron Screen
My sister's monitor wont turn on at all. She was shutting her system down due to a storm rolling in, and it said windows shutting down installing updates, while she is shutting it down. She turned it on today and the little light came on then it went off and hasn't been on since then. The Tower works fine but the monitor isnt turning on at all. What should she do? She has had the monitor at least 2 years no more then 2 1/2 years! And it is a LG Flatron 20". HELP
Apr 25, 2008 | LG Flatron L1751S-SN 17" Flat Panel LCD...
Microsoft Windows XP Home Edition Logo
149 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
