Question about Motorola Mobility RAZR V3
Accidentally locked my razor keypad
How do I unlock my keypad?
    Problem Solver:
  • 9 Answers
If you have not previously set a security/lock code, when it asks you to input the unlock code, enter in the last 4 numbers of your cell number. If that does not work, you can use 0000, 9999, or 1234. Those are most common used default codes. If that doesn't work, see if your phone will allow a network update with *228 or *22899 followed by the send button. If a network update goes through, that will usually reset the code back to default if you had ever changed it, then try the last 4 of your cell number again.
Posted on Sep 14, 2008
I have a nokia e 71 that i have to unlock keypad everytime i want to make a call how do i take the lock off
karenthigpen,
the unit locks automatically to prevent accidental pressing of the keys, you can prolong the lock out time if you wish: select Menu>Tools >Settings >General>Security>Phone and SIM card>Keypad autolock period.
Aug 21, 2011 | Nokia E71 Smartphone
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
Tip
How to lock or unlock a Samsung Intensity
Many people like the Samsung Intensity because of its slide-out QWERTY keyboard. However, one drawback to the phone for some users is that, unlike a flip phone, the numeric keypad is always exposed. When the Intensity is kept in a pocket or purse, this can result in accidental phone calls, multiple all-black pictures, and sudden activation of the voice command feature.
Luckily, you can lock the phone's keypad to keep it from engaging any functions when you're not using it. Locking the keypad is easy. Just hold down the 0 (zero) button for about two seconds, and a message will pop up telling you that the keypad has been locked. While it's locked, you won't be able to use the numeric keypad.
The standard way to unlock the phone is to press the upper right options button (the one that you would typically press to bring up your Contacts list) and then press the center OK button. (You will see prompts for both of these buttons when the phone is locked.)
However, there is also a quicker way to unlock the phone -- just slide the keyboard open. Sliding the keyboard open will unlock your numeric keypad immediately, and even when you close the keyboard the phone will remain unlocked. If you want to lock it again, you'll have to hold down the zero button to re-lock it.
You can also enable Auto Key Lock mode, in case you think you'll forget to lock your phone. With Auto Key Lock mode turned on, your phone will automatically lock itself when it's not in use and the backlight goes off. You can turn Auto Key Lock mode on or off from the Phone Settings menu.
on Jun 28, 2010 | Cell Phones
How to unlock nokia 2700c
Keypad lock
To prevent accidental key presses, select Menu, and press * within 3.5 seconds to lock
the keypad.
To unlock the keypad, select Unlock, and press * within 1.5 seconds. If
the security keyguard is on, enter the security code when requested.
To set the keypad to lock automatically after a preset time when the
phone is in the standby mode, select Menu > Settings > Phone >
Automatic keyguard > On.
To answer a call when the keypad is locked, press the call key. When you end or reject
the call, the keypad locks automatically.
When the device or keypad is locked, calls may be possible to the official emergency
number programmed into your device.
Jun 05, 2010 | Cell Phones
My AX380 cell phone keypad was accidentally locked....I don't have a code, since I didn't mean to lock it. How can I get it unlocked so I can use it again?
Oh..it is to bad for you but I will try my best to help. okay.:-) so just cool and relax. You said you accidentally lock it and forgot the unlock code right? Here's one thing I want you know, it is the best one to do. Get your phone to the authorized retailer and have it unlock or take it a cellphone repair shop, they probably flash your phone and reprogram it.
Dec 18, 2009 | LG Wave AX380 Cellular Phone
Motorola razer bz60 My buttons don't work and
please unplug the old keypad and get the new key pad
Oct 23, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Is there a waay to lock the keys while it is in my purse?
this should help you out.
Basicall press MENU > *
Lock the keypad
To lock the keypad to prevent keys from being
pressed accidentally, in the standby mode,
select Menu, and press * quickly; to unlock,
select Unlock, and press * quickly.
When the keypad lock is on, calls may be
possible to the official emergency number programmed into
your device.
Enter the emergency number, and press the call key. The
emergency number you have entered may not be displayed on
the screen.
Apr 19, 2009 | Nokia 1600 Cellular Phone
V3 razor phone
how did you lock a v3 razr keypad try pressing the menu key and then *
Oct 26, 2008 | Motorola Mobility RAZR V3
Key pad lock and unlock Nokia 1200
My local Nokia Care Center provided the easy answer (which does not appear in the
owner's manual):
In the Menu, go to Settings, then select Phone settings, and activate "Keyguard Settings," and "Automatic." That done, you must select the time interval until the keypad self-locks. To unlock,
touch the "select" key (upper left key) and * (lower left). That combination also will relock the keypad.
Sep 11, 2008 | Cell Phones
Accidentally locked my keypad
well I sat down and started hitting the keys looking for the 3 digit code starting with 100 and going up. Ends up it is a 4 digit code that I found by accident. I hit 2432 and phone unlocked. Give it a try and maybe yours is the same, good luck.
Dec 31, 2007 | Audiovox MVX430
Motorola Mobility RAZR V3 Logo
127 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
