Question about Kenwood VR-5080 Receiver
No sound from speakers
Everythign works fine, except no sound from speakers. The receiver immediately goes into overload protection when turned on. I have checked the thermistor it works fine. All fuses and power supplies are ok. When turned on the cooling fan turns on all 5 relays change from normally closed to open. All channels have individual amplifiers, if one power amlifier is blown ie. Channel A will the overload shut all outputs off.??? Any ideas as to what might be the problem with this damn thing?? Any help is much appreciated.
  • 2 more comments
  • gurmeet mangat May 18, 2006
    Checked out the B+ line and all is fine. I figured out that the +/- 17 VDC (which is the supply for all the IC`s) has gone missing. Next step is to find the regulator. For the IC I only see +2 VDC and -0.6VDC at their corresponding pins. I believe the regulator may be shorted. Any thoughts?
  • gurmeet mangat May 27, 2006
    OK, I have all the schematics for this amplifier. I have checked the +/- 17VDC regulating cct, all components are fine. There is a digital transistor which swithches on the 17V cct when it recieves a pulse from an IC. I am going to try an scope the signal going to the transistor. I did notice the supply voltage for the IC is 4.0VDC when schematic calls for 4.8. Could this be an issue. I have the schematic in pdf format, I can email it to you if you wish, so you can have a better understanding of what I am talking about. Thanks for your help.
  • gurmeet mangat Jan 11, 2008
    I know its been a while, I found schematics. The only Voltage missing is +/- 17 VDC. It is used for the "volume cct" I have the schematics in pdf form and IO can send the exact page were the voltage is missing. How can I go about doing this???
  • phorapples Dec 28, 2008
    I have a similar problem, but there is output it is simply very low. When I turn the volume level to the maximum undistorted sound plays from both speakers fine, but at normal volume settings the sound from any input does not come out or is barely audible.
  • 3 Answers
Send it to Kenwood Authorized Service Center East. They have the fix for your unit.
Posted on Mar 07, 2009
  • Jack Ollila
    Jack Ollila Apr 27, 2014
    Has anyone found a solution for this issue? Thanks!
    President:
  • 3,130 Answers
In most recivers or amps yes if there is a short in one channel all the amps go into shutdown or into the protect mode. Now if you know how an amp works then you should be able with a schematic to find out what amp is causing the over load simply by see in the schematic where the speaker output is on the curcuit and then measure for a DC B+ . Thats the amp you would disconnect to conferm that all the others were ok as an output on an amp curcuit shouldnt have more then .3 to .8 volts dc unless its unbalanced.. Seek a pro to assit you if you dont have the equipment to test the amp and for sure get a service manual or schematic diagram. Good Luck
Posted on May 16, 2006
  • Larry  Dillon
    Larry Dillon May 18, 2006
    To trouble shootmthis correctly your gonnna need a schemaztic diagram see if you can getbon and post the proper part to us and we will assit you. Good luck
  • Larry  Dillon
    Larry Dillon May 19, 2006
    not shorted as if it was a shorted regulator then it would be a very high voltage But I would check for an open resistor 0r an open regulator transistor.
SOURCE:
No sound and light on input selector knob is Flashing. Light only flashes when speaker switch has been turned to A, B or A&B.
This can happen if there's a dead short in a speaker wire or if you're using very low impedance loudspeakers at high volume for an extended length of time. If the protection light came on due to a speaker wire short, low impedance condition or a bad speaker, the receiver's power will need to be turned off to reset it. Before turning the power back on, all speaker wire connections should be checked for their integrity at the receiver side and at the speaker side. If the protection light goes on immediately after you turn on the receiver, disconnect the speaker wires at the receiver side and retest. If the receiver's protection light goes off, then there would still seem to be a problem with one channel's speaker wires or speakers. Connecting them one by one and retesting should allow you to find the problem speaker or connection.
Jan 14, 2015 | Audio Players & Recorders
Trying to hook up Amphony 1600 wireless surround speakers but as soon as I switch the receiver to Surround with the DSP Sound Mode button it plays for a sec then says Overload and turns off. Does it even...
I'd suggest you try the basic speaker setup routine with tones to be sure all speakers work and none are shorted.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Sep 16, 2011 | Technics SA-DX1050 Receiver
Unit goes to "overload" and quits
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 30, 2011 | JVC RX-6030V Receiver
When my Denon AVR 1706 has too loud of sound, it shuts the receiver off. Then it starts up fine and continues to work as long as I turn the sound down. Help................ Ken
What's "too loud"?
Jul 29, 2011 | Denon AVR-1706 Receiver
When we turn on the receiver, after a few minutes the word PROTECT flashes & the sound goes off
from it.
tech.
Jul 10, 2011 | Sony STR-DE505 Receiver
Just purchased a home that has an Onkyo THX Select 2 Surround EX receiver with Bose Surround Sound speakers. When I attempt to turn the unit on, it hesitates a few seconds and then makes a dull click with...
So, it has NEVER worked? Review your connections regarding the speakers.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
Mar 02, 2011 | Onkyo TX-SR803 Receiver
Popping sound when starting up. Using POLK speaker system. Pops once then it goes into protect mode.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 21, 2011 | Sony STR-DE845 Receiver
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
Amplifier displays "Speakers are overloaded" and switches off
Either the amplifier protection circuit is kicking in due to a fault, or your speaker wires are shorting. Could also be a fault in a speaker - shorted turns due to overdriving. Check amp with speaker leads disconnected, and if OK, see above.
Dec 10, 2007 | Panasonic SA-XR55 Receiver
Poor voice track but great sound.
Unhook your center channel speaker and see if it still goes into protect.You might have bad center speaker
Sep 09, 2007 | Sony STR-V555ES Receiver
Kenwood VR-5080 Receiver Logo
742 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
