Question about Emerson EWF2704 TV
Tv. will not come on at all
T.v Was working fine over the weekend went out of town and when I got back no power to turn tv on the remote or the power button on tv does not work The plug is fine because the other tv in the house plus the dvd player still works. what could be the problem.
    President:
  • 3,130 Answers
WQell you could have had a storm pass as you were away or even a power surge and caused the set to shut down the power supply as theres always power on in these new sets as they all have a standby power supply as thats what keeps a voltage and curcuit active so the remote works. If your not a technichian I would advise you take the set into a quilifyed repair shop and get an estimate.. Good Luck
Posted on May 16, 2006
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
All lights are flashing but he dish washer wont start.. was working fine before I went out of town this last weekend..
It might be that you had a power surge try unplugging the unit for a few minutes or trip the breaker.
good luck,
rsmith972278
Oct 12, 2009 | Jenn-Air 24 in. JDB2150AWP Built-in...
TV wont turn on with power button or remote
Try putting the cables back where they were. After that re-route them again but this time use the manuel.
If that doesn't work, consult the TV's manuel.
Jul 04, 2009 | ViewSonic N3735W 37 in. LCD TV
Panasonic HDTV /no power
the loss of power was do to a blown fuse. could not access it through the small opening near where the power cord went in at the back of set.. carefully took the back of just far enough to access the fuse and replaced it. Working fine.
Nov 25, 2008 | Panasonic CT-36HL43 36" TV
GE Fridge/freezer not working properly!
hey ur thermister has worn out may be due to the power surge when the power came back at that time so change the thermistor then check it out.........
Sep 09, 2008 | Refrigerators
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
Won't turn on
my orion tv is not working,it just stopped
Apr 29, 2008 | Televison & Video
44" dlp hd44lpw62 won't turn on
I would first suggest removing AC power to unit for several minutes in order for unit to reinittialize; other than that, check out the power supply to determine if you may have a blown primary fuse or lost one or more voltage sources.. thats where to start....
Sep 10, 2007 | RCA D44LPW134 44" HDTV
TV won't turn on - hums when remote is pressed
did u remember if u left ur tv on when u went out of town for one week? well probably a blown capacitor in the power supply circuit is the one u've heard. the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician.
Jan 05, 2007 | Sony KV-32S26 32" TV
Emerson EWF2704 TV Logo
131 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
