Question about Gaggia Classic Espresso Machine
Gaggia group body/suction pipe jam
Heres the story.
I picked up a Gaggia espresso (a few years old, not the most recent model) that hadnt been used in a long time. I followed the instructions for cleaning but noticed a fair amount of crud coming out of the steam wand every time I opened it. To fix the problem I made a vineagar/water solution and after limited results with that I ran straight vinegar through the machine. There was alot less crud, but water was no longer coming out of the brew head, instead all leaking back into the resivour via the saftey valve. The steam wand still functioned with steam or water. After opening the machine and boiler up, I belive that water is jamming in the group body (28) or the copper suction pipe (17) as labeled here http://www.gaggiaparts.com/GaggiaEspresso.html
it seems that there is some rubber thing in the way of the suction pipe at the bottom of the group body. Any help on this matter is greatly apprecaited! Thank you!!
-Alex
  • aroe Oct 08, 2008
    Fixed!
    After flushing probably close to a gallon overall of vinegar through the machine and soaking the group body in vinegar I finially found the issue. The jam was indeed in the group body, after learning that the suction tube was removeable I discovered a small hole that was clogged. I used a small nail to clear the blockage and when I put it back together it was working great! I would be happy to post pictures if anyone is interested. I also dont belive the vinegar did much, it was certainly much more effective to go inside and clear it myself
4 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: gaggia baby espresso machine - water comes out of
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Posted on Oct 21, 2009
EsWorld
  • 1618 Answers
SOURCE: no hot water or steam from wand.
If steam wand is not blocked then the problem is on the inside of the machine, try descaling the machine that might clear the blockage in the steam line.
Posted on Nov 29, 2009
  • 29 Answers
SOURCE: gaggia titanium. The water and steam are all
This is hard to picture. The only way water can come out the brew spout is if the brewing mechanism inside in the position to make coffee. The only way to get that mechanism into that position is to either select one of the three coffee buttons (you'd hear the grinder run, then you'd hear the motor putting the brew mechanism into place and then the pump start and water would then come out the brew spout. OR to select preground coffee and then select one of the three coffee sizes - in that case you wouldn't hear the grinder but you'd still hear the motor turn the brew mechanism into brewing position and then start the pump.
When you simply select hot water and then open the steam valve - I can't imagine any possible way for water to come out the brew spout.
Now if you mean that you don't see any water come out but water is leaking inside the cabinet and ending up in the drip tray - then that would mean a leak inside the machine. It could be the valve that the brew group locks into when it goes into brew position (you see this valve in a little recess behind the brew mechanism when you take the brew group out to clean it). Or it could be a leaking steam valve or hose inside.
You might try getting a flashlight and a cleaning brush - take out the brew mechanism and then clean around that little nozzle/valve that is in the recess just the left of center behind where the brew mechanism was. That valve should shut when you are not in brew position and not allow any water out - but it may be gummed up with coffee grounds.
If you are feeling brave - you would need a deep socket and a lot of patience with a small breaker bar (a ratchet head is too big to fit in there) and you can remove that nozzle/valve and then clean it or replace it. But it is very slow going to remove it (there must be some special tool they use at the factory). I had just the right size deep socket (like what you'd use for a spark plug in a car) but there wasn't room for a ratchet so I had to use a small breaker bar and I could only turn the valve about 1/4 turn at a time then I'd have to reposition the socket to do another 1/4 turn. It took 5-10 minutes to remove it - then it was easy to clean. I think you could clean it in place with a stiff bristle brush and some q-tips.
I don't know if that valve is the problem - but that's the only thing I can think of that would have your hot water and steam running into your drip tray instead of out the steam wand.
Posted on Nov 03, 2010
Water leak inside of unit around pump head
1. Disconnect electrical supply.
2. Remove top cover.
3. Remove pipe from elbow on top of pump body by unscrewing knurled collar.
4. Then, unscrew elbow from pump body.
5. Wrap threads of elbow with a few layers of plumbers PTFE tape.
6. Then carefully screw elbow back in to pump body (this can be a little tricky - be gentle and take your time - this worked fine on my Gaggia Classic).
7. Then re-attach pipe with collar. NOTE: The top of the pump body can be rotated by gently twisting - to get the pipe at the correct angle to the boiler and allow the pump to sit vertically on its bracket.
8. That's it! Check your machine is dry and clean, re-assemble, plug it in, prime the pump (it's in the manual) and pull a shot!
Jan 25, 2014 | Gaggia Classic Espresso Machine
Watery espresso (puck?)
As far as repairs, Sounds like the seal is wore out and is causing air leaks,
For repairs I need make and model of the machine to locate service, or you could enter it in on the main home page of this site.
Nov 15, 2007 | Gaggia Classic Brushed Stainless Steel...
I have a Baby Gaggia, several years old. I buy IZZO ESE pods, which I understand should fit the holder. They do not in that a pod sits loose in the holder, with a margin round the edge between it and the...
Please try the following:
  • Remove the portafilter and activate the brew switch. Water should stream out of the shower screen. If not you need to clean the group components, or the machine is broken.
    To clean the group components, remove the center screw. The screen should drop down, the dispersion disk may be stuck, you can pry it loose with a flat head screw driver. Soak both of these in a descaling solution.
  • With the group components removed (as above) try brewing, water should stream out of a single hole. If not, you may have a faulty pump, or seals.
  • If water streams out normally, be sure that you are using the single espresso basket. This is the smaller basket that snaps into the portafilter, and has sort of a tulip shape.
  • Your group head gasket may be worn, and will need to be replaced. These need replacement ever 6 months to 12 months, and need to replaced even if the machine is rarely used, because they are made from natural rubber that dries out.
    Replacements can be found at many retailers online, a few are:
    espressocare.com, espressoparts.com, and seattlecoffeegear.com
Mar 02, 2011 | Gaggia Baby Espresso Machine
Have a Gaggia Cyncrony Compact Coffe Machine that doesn't brew!
Has the machine been de-scaled recently? I would run a descaling solution through the machine first to eliminate that.
Jan 15, 2010 | Gaggia Syncrony Compact Coffee...
How do I replace the group gasket?
1. empty the water tank
2. turn machine upside down
3. remove shower rose(one screw in middle)
4. remove group head (two hex screws)
5. pry out old gasket
6. fit new gasket and reassemlbe
Dec 25, 2009 | Gaggia Classic Espresso Machine
Can't remove rubber seal from Espresso Gaggia /A machine in ...
Screw a self tapping screw into the perished rubber seal. Then pull it out with a pair of pliers.
Sep 14, 2009 | Gaggia Baby Espresso Machine
Gaggia Classic Group Head Stuck
try this website http://www.bluebox.com.au/jcrayon/gaggia/
Mar 06, 2009 | Gaggia Classic Espresso Machine
Low water flow from gaggia evolution only 6 months old, have tried descaling, no obvious scale found in machine. pump starts but goes quiet, very feeble flow of water.
I have now solved this problem. The lack of flow associated with the pump working but running quietly is caused by the Group Head being blocked with limescale. Normal descaling cannot remove it because it cannot penetrate the Group Head.
Removing the Group Bell can be achieved using a collection of screws (see photo) and works no matter how stubborn the thing: levering it with a screwdriver in my case was impossible as it was so well glued on. 6d47425.jpg
I figure that the advice to replace the rubber seal once per year is a good one because it forces you to remove the Group Bell and clean it out.
Apr 29, 2008 | Gaggia Baby Espresso Machine
Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Apr 09, 2007 | Gaggia Coffee In White, White MDF...
Gaggia Classic Espresso Machine Logo
124 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
