Question about Kitchen Ranges
How does drip tray for cooktop fit above grill should it touch the element? it is a chef supreme upright approx 2000 year
    Sergeant:
  • 409 Answers
The drip tray should not touch the element all. it will cause a problem when you run the self-clean. sounds like the cover is too big.
Posted on Sep 13, 2008
New knobs & pans
A good place to start is the local agent or manufacturer,
Apr 09, 2014 | Jenn-Air Removable Cooktop Grill - Part...
I replaced the porcelain enameler flavorizer bars on my Weber genesis gas grll less than a year ago--four out of the five bars are bent and misshapen--no longer straight. Why??? They still look brand...
You are overheating the grill - make sure the thermometer is working on the right side of the grill lid. You should not heat above 550F (preheat) and you should not cook above 500F.
Secondly, you must clean out the drip tray (not just the aluminum foil tray but the bigger tray it is attached to (it slides out the front of the grill too). The grease that piles up on this tray can catch fire and overheat the grill (including the flavorizor bars).
Last suggestion is to get stainless steel bars next time (make sure you get the size that fits your grill because the stainless steel sizes also come a bit longer). The stainless bars are high temperature stainless steel and do not corrode. They are a bit heavier and cost about 30 to 50% more but well worth it. They clean up very easily and transfer heat to the cooking surface well. Keep them clean to keep the cooking surface hotter.
Jul 16, 2011 | Weber Genesis Silver B Grill
My franklin chef FIM200 is dripping water from the back, right side. The water fill valve was spraying out above the tray, we managed to get that under control, but, water is dripping right behind that...
Try putting a compression coupling in eliminating the valve. Did that on my machine a few months back, have not had any more leaks. Just other issues with thick ice and won't harvest correctly. Any suggestions?
Nov 24, 2010 | Franklin Industries Franklin Chef FIM200...
How do I access the spill tray under the element of a chef stove in order to clean it?
Make sure that all of your burners are off and cool. Raise the stove top. It should tilt from front to back. There will likely be rods inside to hold the top open.
--Regards, --WoobieDog--
Jul 10, 2009 | Electrolux Cooktops
My Magig Chef Glass Rangetop
This part can cost over $400. It is usually not worth fixing. NEVER operate the stove with a cracked top. This is tempered glass and it can just explode! It is also a dangerous electrical issue. Liquid can drip down through the crack and contact the live open element.
Jul 13, 2008 | Magic Chef 30 in. 8241RT Gas Cooktop
Replacement grease catcher
I am using a disposable foil loaf that I bent to fit in the drip space.
May 18, 2008 | George Foreman GGR50B Grill
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
