Question about SanDisk Sansa e260 MP3 Player
MY SANSA WONT SYNC SONGS..
WHEN I SYNC SONGS ON IT, IT WILL SHOW ALL THE SONGS ON THE DRIVE. BUT WHEN I DISCONNECT IT FROM THE COMPUTER, THE SONGS DISAPPEAR ON THE SANSA....
  • 8,596 Answers
The songs are in the wrong format - they need to be stripped of their DRM license (illegal) or converted to mp3 format.  The best, most legal way to do this is to redownload the songs as an Mp3 file, or re-rip your CD's in Windows Media Player in Mp3 format.
these problems occur because the user is trying to download a song format that the player does not recognize. Every music file is in a certain format. The most common music file formats are Mp3, WMA, AAC (iTunes), WAV, RA, etc.  In addition, every file format type is in a certain bitrate, size, etc.  By far the most common issue is that the music file contains a license or copyright (especially with WMA or AAC file formats).  Each Mp3 player only recognizes a certain number of these formats. Every Mp3 Player is different. You will have to check your Mp3 player’s product specifications (specs) or user’s manual to find out which formats your particular Mp3 player recognizes. When you try to download or sync the wrong file format, you will get one of the errors that I mentioned above.   If you want to know what file type you have, then you must find the location of the individual music file on your computer, right click the title of the song, and select the option “Properties” from the menu.
Mp3 player product documentation is not straightforward.  If a player supports only non-protected WMA files, it will merely say that it supports WMA – it will not tell which type of WMA it supports.  A player that supports DRM-protected WMA’s will usually indicate such on the box (usually with a Windows Plays For Sure logo – which is actually an ironic misnomer).  DRM stands for Digital Rights Management, and it is a type of licensing system for WMA files.  It is used extensively by mp3 player music services such as Bearshare, LeapFrog, Napster, and others.  Not all DRM licenses are created equal – there are licenses with “play rights,” burn rights,” and “transfer rights.”  Play rights mean that you can only play the song on your PC – it will play fine on your computer, but it will not play in your mp3 player even though it appears to transfer.  Burn rights mean that the song can be burned to CD.  Transfer rights mean that the song can be transferred onto an mp3 player that supports DRM-protected files.  Then, there are unlimited licenses and limited licenses.  Limited licenses only allow you to play a song for a certain length of time. You would have to pay extra to continue using the song after that trial period is over – the time length ranges from a few days to several months or longer.
-Tha Mp3 Doctor
Posted on Sep 13, 2008
I dont have sandisk driver for my sansa E260..i cant transfer songs..
Sansa Not Recognized: Try connecting it to the back of your computer or another computer the back straight to the motherboard this should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect.... Sync to upload songs to the sansa......Hope this works
Dec 01, 2010 | SanDisk Sansa e260 MP3 Player
Sync songs don't show on my player
It says in the user manual for C-100 sansa player that "various software packages are available to syncrhonize your songs on your device. Please refer to the specific software package instructions. "
I used Windows Media Player 9 and when you use these older Media Players you must remember to change your USB setting on your Sansa player to MSC. Turn on your Sansa Player, Choose the Main Menu and select settings. Don't choose auto-detect, but select MSC. If you choose auto-detect it will default to a setting called "MTP", and MTP wants Windows Media Player 10 to download your stuff.
I'm not familiar with how ITunes works, but perhaps AUTODETECT will work to synchronize your files.
Good luck.
Jun 22, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Cannot delete the songs on mp3
I do mine through Windows Media Player
1)Plug in Sansa
2)Open up Windows Media Player and wait for the Sansa e250 icon to show up under the library. First time, might say 'What device is this' or 'Autoplay'-for autoplay,you click 'sync media files to Sansa e250 using WIndows Media Player'
3)When library shows, click 'Sync' if it is not already there.
4)Just simply click and drag the songs you want from the computer library to the list pane on the side.
5)Once your done, click 'Sart sync'
TO DELETE
1)Plug in
2)Wait for the icon under Library in WIndows Media Player
3)Go to Songs under Sansa e250
4)Right click desired songs and choose Delete. You only want to delete from Sansa e250-nothing else
~loli~
Dec 23, 2008 | SanDisk Sansa e250 MP3 Player
My songs wont add onto my sandisk sansa mp3 player
What format are the songs you're not able to hear? It's possible that the songs are not in a format the Sansa can play.
Also, you can navigate your Sansa like a removable drive. Try going to "My Computer" and looking to see what's actually on the drive.
Nov 27, 2008 | SanDisk Sansa e250 MP3 Player
Some songs wont delete
Delete from the Windows desktop if possible. Double click on My Computer. Double click on the icon of the Sansa. Go into the music folder and delete from there.
Or
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Apr 15, 2008 | SanDisk Sansa e260 MP3 Player
Not able to see songs on the computer even though they are in the player
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Mar 28, 2008 | SanDisk Sansa e260 MP3 Player
Adding music to my sansa e250
you must use windows media player 10 or 11 to sync songs into the sansa. Make sure you sync it this way or else your songs will not go in properly.
Jan 21, 2008 | SanDisk Sansa e250 MP3 Player
My Sansa E250 is having problems
Reformat
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
Sansa M230
-Tha Mp3 Doctor
Nov 25, 2007 | SanDisk Sansa m230 MP3 Player
My e250 wont play some songs, they are marked as unknown
-Tha Mp3 Doctor
Jan 28, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
365 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
