Question about LG DR-4810 DVD Recorder
LG DR-4810 DVD Displays " PLEASE WAIT"
The DVD recorder just displays "PLEASE WAIT" There isn't a DVD disc in the Player/recorder. I replaced the DVD/Recorder Player unit and when the machine was plugged into the mains - Yes you have guessed it it displayed "PLEASE WAIT". You can hear the dvd player running but the machine is not getting the message that there is not a DVD disc in the caddy! PLEASE HELP -
  • Anonymous Mar 21, 2014
    when pwered up player just displays please wait
  • Anonymous Mar 26, 2014
    Hi,I have a LG BD550 the machine powers on but does not go past the LG start up screen, the machine doesnt want to eject the discs play the disc and no matter what buttons i press on the remote or the unit nothing responds. Its like the player is frozen please can someone assist me.
  • 513 Answers
To open the tray during "please wait", remove casing then loosen front panel (clips either side and underneath). Power up to get "please wait", then press small microswitch in bottom right corner of the DVD player unit. Have you tried resetting the unit (turning on and holding the power button for at least 5-10 seconds)? Have you tried unplugging the unit for a longer period of time (24 hours)? get your firmware upgrade through here(sorry its in german, you might be able to get an english of it through the LG site) - http://www.lgupdate.de.ms/ two cd's- bootloader.iso , update.iso Good luck
Posted on May 17, 2006
C113 10v 1000uF cap off an XFRMR in power supply board. Cooked and gone high esr. Replace with a 16v.
Posted on Nov 26, 2007
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Have the same problem on a LG BH6220S Bluray player. Opened the drive manually and the IC code is "D78F11652" but nothing found in the www. Anybody deeper knowledge ? The board code is EAX64508381 - BTW: Checked already all cable connections.
Posted on Jun 15, 2014
  • 4 Answers
1)DVD tray is jammed check it carefully 2)check the motor 3)If the above solution couldn't solve the problem trace the drive IC no&post it to the URL"DATASHEET CATALOG.COM"& study the IC's features & replace the corresponding IC from the motherboard of the IC otherwise replace the motherboard.thanks you can always ask question@ sudheer2scorpio@yahoo.co.in thanks
Posted on Jul 08, 2007
There is problem in your drive IC which control the tray motor . trace the IC or replace it orreplace motor. thanks... By sudheer
SOURCE:
Please wait lgdr4810
Replace all power supply's capacitors that are on the secondary.
This should help solve the problem.
Feb 01, 2011 | LG DR-4810 DVD Recorder
What are the best discs to record on with a LGdr165 recorder
try Maxell from costcos, bestbuy or jandr ... (Dynex or Pansonic is good if you can not find Max)
Oct 17, 2010 | LG DR-4810 DVD Recorder
When i turn power on display scrolls "please wait" over and over and will not do anything else.
it may be, because of your unit has component problems and needs service/. it means it takes long time to recognize the condition.
Dec 23, 2009 | LG DR-4810 DVD Recorder
Does not read the disc
clean the laser , if that doesnt fix it, replace dvd loader
Jun 30, 2009 | LG DR-4810 DVD Recorder
Lg dvd recorder
No, this is a fault with the unit, 99% of the time caused by the power supply, but I've seen it be caused by the MPEG pcb
Apr 21, 2009 | LG DR-4810 DVD Recorder
LG DR4810 DVD recorder says disk is full when it's not.
Have you tried a different disc? Some discs do go faulty. Is the disc compatiable with the machine? Try erasing the disc and starting again.
Feb 01, 2009 | LG DR-4810 DVD Recorder
I have a lg dr 165 dvd player and it does not play region 1 dvds
1. Power on
2. Open DVD tray
3. Press 7 times 0 on the remote control
4. You will see a "Now zonefree" confirmation message on the screen.
Dec 21, 2008 | LG DR-4810 DVD Recorder
LG DR 165 DVD Recorder problem
hi , how are u friend
i have problem pls can y help me
lg dr4810 afiche in lcd (please wiat )
Sep 28, 2008 | LG DR-4810 DVD Recorder
LG DR 165 dvd recorder
Hi,having the same problem for the second time :0( Had to take it in to LG,had the lazer replaced... i heard it is a common fault..
Hopefully it is still under warrenty...
Hope you come right :0)
Oct 11, 2007 | LG DR-4810 DVD Recorder
LG DR-4812W seems to get stuck
leave your dvd player off for about 1 week.if it still do the same thing then you will have to replace it.good luck
Jul 06, 2007 | LG DR-4810 DVD Recorder
LG DR-4810 DVD Recorder Logo
2,167 people viewed this question
Steve Allison
Steve Allison
