Question about Whirlpool Washing Machines
Hi I have a whirlpool top loader washing machine about 10 years old. It is not spinning. where is the model number on the machines and what could the problem be?? thanks annette
  • 943 Answers
HI thanks for the question When you put the lid domn can you hear the motorstart if no you need a lid switch if yes you need a motor coupling thanks THE APPLIANCE DOC
Posted on Sep 13, 2008
My whirlpool top loader extra large washing macine
Many late model washing machines use a direct-drive system to agitate and spin. They don't use belts or pressure wheels to transfer power and motion from the motor to the transmission. The motor is coupled directly to the transmission. If the motor is running and there is no agitation or spinning of the tub, the culprit is usually a plastic coupling between the motor and transmission or the transmission itself.
Aug 07, 2008 | Washing Machines
Whirlpool super capacity plus (commercial quality top loader) does not spin on all settings and does not spin fast enough
sounds like you have a worn out clutch. depending on model it could be an easy fix. would need to know model number to know for sure.
Apr 03, 2013 | Whirlpool Washing Machines
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
I require a user's manual for a Whirlpool washing machine that is approximately 10 years old. I don't know the model but the serial no. is 34 9945 011318
with out model number you will not be able to get the manual, the model number is usually on lid/door rim ,inside the lid for top loaders and inside door for front loaders
IF ya find the model number go here and download the manual http://www.whirlpool.com/owners-center/owners-center-homepage.content.html
Aug 03, 2011 | Whirlpool Washing Machines
I have a Kenmore top load washer model 20692. The washer won't drain and whenever the washer is supposed to turn all I hear is a hum. What could be the problem and is it worth fixing in a 10 year old...
Sounds like you have multiple problems...you are right... probably not worth fixing...
Look at the front loaders... they use way less water and are more gentile on your clothing...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 08, 2010 | Kenmore Washing Machines
Why my whirlpool washing machine wont spin model # LXR5432KQ0
If this is a Whirlpool manufactured TOP LOADER washing machine, a no spin problem can have several causes. Most commonly, this is caused by either a lid switch malfunction or a broken motor coupling. The following link explains how you can diagnose the problem and repair it yourself:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
Read through the link provided and let me know if you have any questions. I have included parts resources and instructions on how to replace each part as well.
The part number for a replacement lid switch is 3949247. The motor coupling part number is 285753A.
If you have questions, please post back and let me know. I hope you find this information helpful.
Apr 14, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool wont go in to spin turned machine to
might be a bad lid switch or the couple between the motor and trans could be broken
Feb 27, 2010 | Whirlpool Washing Machines
Kitchen aid top loader washing machine does not spin
Peace Friend,
ngfam1 At your service!
Sounds like a belt problem!
Or the linkage connecting the transmission to the agitator.
Or the WORST THE TRANSMISSION IS GOING!
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 30, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal De
