Sansui LCDW2300 23 in. Television
Problem for Sansui LCDW2300 23 in. Television
Sansui picture fault
By lesw on May 15, 2006
my combined 32" Sansui tv/dvd has developed a fault. It has a thin red vertical line about a quarter of the way across the screen. Any idea how to fix it/ what is wrong?
Comments:
May 17, 2006
- Thanks for your help. It was only 2 weeks old, so I've returned it to the store. they should either fix or replace under warranty. Best wishes LES
Best Solution
posted on May 17, 2006
Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3620 votes
Usualy a problem with the LCD screen itself, that takes replacing the whole screen to fix. Sorry.
Could also be an internal connector that has gone bad. There are tiny transistors on most displays that control whole rows and columns. It sounds like one went bad, causing a dead, or constant on, column. Unless you are REALLY handy, it will probably need to go to a service center for repair, which could be very expensive.
Try flexing your screen - wrap a non-fibrous cloth around your
hand and squeeze the screen lightly all around the edge. If you
find a point where squeezing the screen makes things better or
worse, explore that point further. Squeeze just hard enough to
make a white area go light grey or yellow. It's safe to squeeze
gently with something fluffy when the computer is turned-on.
Could be a cable problem - either the cable is not making
a good connection at one end, or the cable itself may have
been crushed and one of the lines in it broken. Replacing the
cable is far cheaper than replacing the display.
Good luck
Was this helpful?
Yes
No
Popular Solutions for Sansui LCDW2300 23 in.
Questions and Unsolved Problems for Sansui LCDW2300 23 in.
Do you recommend Sansui LCDW2300 23 in. Television?
Answer
Answer
I bought a Phillips Universal remote control to use with my Pyle TV. The Pyle brand is not listed.... (More)
Answer
The picture is green. Even resetting does not work
Answer
fuse blown replaced, blown second time.Any ideas
Answer
i own sansui lct26sd bought yesterday i need to remove the stand so i can mount it on the wall i... (More)
Answer
Hello, I removed the bottom stand so I can mount the tv on the wall. I still have all the pieces... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , OH
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
