Question about Goodmans 255NS 25" TV
Cant See bottom half Of Screen On My TV
I have a goodmans tv 32" and for some strange reason it cuts of about 4" off of the bottom of the screen. i have tried to change the screen sizes but still no luck.please HEEEEEElllllllppppppp
    President:
  • 3,130 Answers
If your a technician i would tell ya to go into the set and change a couple of choice capacitors and possibly the vertical output IC.. if your not a tech then you cant service this set by your self as there are no serviceable parts inside the set so you should really take the set in and good Luck!
Posted on May 16, 2006
The score on football games on fox and cbs are halfway off the screen. How do I fix this?
Hello
It is likely that you have the "picture size" set to a mode that does not match what the channel is actually providing.
Go to the Menu options on your TV and then look for the Picture options. Change the size between the different options (typically 16:9, 4:3, Wide, Fit to Screen, etc.) and see which mode works best for the Fox and CBS broadcasts.
It is likely you have the TV set to Wide or Fit to Screen. Both change the settings to make 4:3 broadcasts fill the screen of a wide screen TV. Changing this to 16:9 should allow you to see the information on the sides and bottom of the screen again.
Nov 03, 2013 | Insignia IS-LCDTV32 32 in. Television
Change tv screen size
Refer the user manual to your TV for details about changing the aspect ratio of picture.
Jul 10, 2013 | Sanyo Televison & Video
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
My screen does not cover the whole screen. It is not on widescreen mode, but it is a shortened picture and some of what I am watching is cut off.
A lot depends on what the TV station cuts off also.
If they are transmitting a 5 X 4 picture, your TV will try an reproduce it giving cut off edges or top and bottom. It won,t fit properly.
Hope that helps to explain it.
Jan 22, 2011 | Sharp LC-32SB24U 32 in. LCD TV
I just changed from Comcast Cable to Verizon Fios. Since the change I am unable to get a full picture on Fox News. There is a narrow horizontal picture with 1-2" black bands across the top and...
This is a function of your set-top box (STB), and has nothing to do with the TV. I know several FiOS users with the same trouble, and it's annoying but there isn't anything you can do to "fix" it. What is really strange is that the screen size can change even on the same channel, depending on the particular program being broadcast. It has to do with the aspect ratio of the programming from the provider.
Jan 12, 2011 | Panasonic CT-32G23 32" TV
My sony 32 tv screen cuts people's heads off. what can i do to correct it?
Look in ur remote control for a button like Zoom, Aspect,VIEWMODES,P.Sizes.Tries one of these buttons to tuggles the pictures sizes on the tv screen.
Dec 11, 2010 | Sony BRAVIA KLV-32U100M 32 in. LCD...
My Sanyo TV was plugged in, I was watching it and all the sudden the screen went gray wash, then it cut off. You can plug it in the wall and it will try to cut on but cuts off after like 2 seconds. It also...
U have a soldering iron,solder?Now basic soldering?Unplug the tv wait about half an hour for the highvoltage to disapear.Take the tv aparts.Resolders the Video board that connected to ur CRT Tv tube.Resolders all those coldsolders pins sockets pins on the video board,will solved this problem.Have fixing these problems many times on the CRT Tube computer monitors,when it was still popular.
Sep 09, 2010 | Sanyo Televison & Video
Trying to change tv format on my dynex 32 LCD
You are looking for a picture size, format or screen size button on the remote control to solve the issue. If it connected to a HD cable or satellite box then they also have format or picture size settings.
Apr 13, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Goodmans HDMI. After power cut (which it is used
I just left the TV off and it must have reset itself. It did it twice. First time it was OK after half an hour. Second time it was nearer an hour.
Thanks
Jan 08, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Televison & Video Logo
100 people viewed this question
Top Goodmans Televison & Video Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
