Question about Nitro BMW-482 Car Audio Amplifier
Red protection light
Rca wire are hooked yp to my radio but when i hook them up to my nitro bmx 2000 watt amp the red light blinks and the sounds stops from my car speakers and when i unplug the sound comes back also my amp isnt turning one... do you think you could help me?
  • 631 Answers
If the amp is going into protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Posted on Sep 14, 2008
Amp stays in protect with RCA cables hooked up tried different radio RCA cables different amp try in my friends vehicle and worked I'm clueless any ideas I have nitro amp speaker is good it's a type r...
If it works in your friends car but not in yours, it sounds like you may have shorted or rca issues in your car. If you can run a different head unit and rca's in your car but the same amp and see if that works.
Apr 06, 2014 | Car Audio & Video
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
I have a nitro 1200 watt amp that was working great until it a red light that read " protection mode" turned on
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty
Definitely is worth .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-1200-watt-amp-working-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
Aug 25, 2010 | Nitro BMW-482 Car Audio Amplifier
Kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Apr 03, 2010 | Car Audio & Video
The portection light on my alpine mrv-1507 wont let me get any sound
remove the rca wires and the speaker output wires and just leave the 12volt power/ remote/ and ground connected. turn on the radio and see if the light goes off. if it does then one of your speaker or rca wires are shorted, plug in one at a time and see which one gets you the red protect light, then find the short for that speaker/rca wire. if the red light turns on with only the 12volts/remote/ground, then the short is in the amp.
Feb 26, 2010 | Ohm Crystal Mobile Sound CADT 600.2...
Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
I have a nitro 1200 watt amp earlier today it was workin with no problems we parked then came back in the car 3 hours later and it wasnt workin wont come on or anything just red light which is protecting...
Check your speaker wires, make sure everythings connected right with no short circuits, and check all of the fuses in the amp, and make sure none of them are blown. If all this checks out just check the battery wire, grnd, and remote wires. It has to be a wiring issue unless you busted your amp, but if was working when you tuned it off it should be alright... hop this helps...
Sep 10, 2009 | Nitro BMW-484 Car Amp
California 3600 mosfet discrete 3 ch amplifier 600 watts does not work
It sounds like it's going into protect. To be sure it's not the wiring, disconnect all speaker wires from it. If the light still goes out, check the DC voltage on the B+ and remote terminals. Place the black meter lead on the ground terminal of the amplifier. If the voltage remains above 11 volts as the amp tries to power up, the output transistors are almost certainly shorted causing the amp to go into protect.
Nov 25, 2007 | Profile 600MSX Car Audio Amplifier
Nitro BMW-482 Car Audio Amplifier Logo
180 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Michael Kovalik III
Michael Kovalik III
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
