Question about Frigidaire Washing Machines
Dr code comes on when starting washer door is closed
  • 706 Answers
Try pressing options and hold it on for ten seconds ' loc' should come on, then do it again to turn it off. Make sure the door is closed properly and that the door switch senses the door is closed. Hope this helps..
Posted on Sep 13, 2008
Wtat is the dr code error?
Hello Aung, I appreciate your post!
Based off what you have described your Electrolux washer is displaying an error code of "DR". The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. You should perform a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Dec 30, 2015 | Electrolux Washing Machines
Why is my frigidaire affinity atf600sfo washer displaying a DR when I push start?
Hi adakota5267, thanks for the post!
I understand that your Frigidaire washer, ATF600SF0, is now displaying DR. DR stands for door open or door problems, which could be an issue with your door switch or wiring issue. Sometimes the issue can be resolved by opening and closing your door once more. If the issue continues I would recommend having a technician out to your home to diagnose and repair the washer. -Matt
Jul 25, 2014 | Frigidaire Washing Machines
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer will not start. Getting "dr" message . Door lock light is not lit. Tried cancel and restart tried unplug and restart still getting dr message
The 'dr' error code stands for 'door switch is not closed'. If the door is closed properly, then you will have to replace the door switch assebly.
Hope this helps!
Jun 25, 2010 | Washing Machines
My frigidaire front load stackable gets a code dr. model#fwtbb30ds0
Hi.
Error DR is door latch error.
Check the door lock, and ensure that it it closing and opening properly.
Disconnect power cord or trip circuit breaker for one minute to reset the error code.
If the error code comes back, then the door lock may be faulty.
The door lock may be tested removing it from the washer and reading Ohms on the terminals to ensure that it is opening and closing the circuit. An alternative way to test the lock is by jumping it, if error comes back with door latch jumped, then fault is on wiring or controller board.
Here all parts and diagrams for this appliance.
Regards.
Ginko.
May 19, 2010 | Washing Machines
My affinity washer will not close to start a cycle. the buzzer goes off and i get the code "dr" but it seems to close fine
Have a service technician test the sensor in the door jam that senses when the door is closed (this is signaled by the electronic lock).
Dec 14, 2009 | Frigidaire Affinity ATF7000E Front Load...
Error code
'dr' is an error code that indicates the door is not closed. If closing properly the door lock may have to be replaced.
Jun 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Jan 24, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Washing Machines Logo
41 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
