Question about Philips 43P8341 43" Rear Projection Television
Blank Screen I want to know how to re-place a part if my TV has a blank screen and no sound.
  • Roanna Yutig May 16, 2006
    Can you help me fix my blank screen i lost my job so i need to do it myself. I know technical stuff though.
  • Roanna Yutig Nov 21, 2006
    Hi Techman i was wondering I had 2 repair guys come to check out my philips 43 in tv. They were saying it was the power supply module something like that. Do you know how much it cost and do you know if i could replace it myself?
    President:
  • 3,130 Answers
There is not just one part that will fix a dead set!! theres about500 or so I would say and its best that if you tryed all the obvious things such as wall receptical, Curcuit breaker for the room, make sure its pluged in or see if the master switch is on if there is one. I would highly recommend that if you have no electronics background then Please have this looked at by a well qualifyed technician!!!! if you have then I would start with the power supply. Check the main AC fuse and see if its good .. If its good then start to measure B+ at the main input caapacitors. If voltage there(like 265 to 200 vdc then start with the regulator cucuit. if you get through the power supply and all the voltage is correct on the schematic then go into the horizontal sweep and start trouble shooting there. Its really hard to troubleshoot a set in the blind but you can if you wish get a schematic and post it here and we can assist you and give you advice on where to go from there. Good Luck
Posted on May 15, 2006
SOURCE:
TV screen is blank but the program is still playing
Check the cables, makes sure all connections are still snug. If your using HDMI, try swapping it out for one you know works. There are a lot of lemons out there.
Feb 24, 2016 | Televison & Video
Emerson TV no picture, but still have sound
If this is an LCD TV, show a flash light (torch light) on the screen from a safe distance.
If you can see the picture, the backlight has gone off and might need
of a qualified service technician.
Aug 05, 2012 | Emerson Televison & Video
Phillips 47pfl3603d blank screen with sound
if the Tv have back light the problem is t-con if not the problem is inverter
Jun 06, 2012 | Philips 47PFL3603D LCD TV
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
While watching tv the screen will go blank, sound
It might be a loose solder connection inside,try to prove it,the next time it goes blank,firmly give a whack to the back or bottom of the set,if it flashes back......sholud be a loose solder conn that a competent technician can find and repair
Jun 02, 2010 | JVC AV-32F704 32" TV
BELL HOWELL 17462 PROJECTION SET TV SCREEN WENT BLANK
Do you still have sound? Can you see light at the back of the set when the screen is blank -if so the bulb is ok and you've just lost video.
Oct 14, 2009 | Televison & Video
Sceptre naga blue screen when tv on then turns blank, sound on
i have a secptre t v turns on for a sec and screen is blue then goes to blank screen can anyone help
Apr 18, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Philips 43P8341 43" Rear Projection Television Logo
389 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
