I have plastic cover migration to my CD's. Slight problem is removed by alcohol; but some discs will not clean, and the disc is not readable. Help.
  • 9 more comments
  • jonpardoll Sep 13, 2008
    I have tried the water washing method. It does not work on the discs with moderate to heavy migration.
    I have tried the water washing method. It does not work on moderate to more serious discs with the problem. I have tried toothpaste. It also does not work.
    I understand solution #1; which is why I am looking for a real solution to this problem. There must be a way to burnish, or polish the plastic back to a clear surface...
    I will look forward to other expert advise. Thanks.
    As I said this is not a scratch problem, but a mottling of the surface of the plastic on the disc. I need to polish off the mottling which is now within the surface of the disc.
    I will wait for usable response here. So far nothing suggested has worked.
    Somehow, some way, there must be a way to repolish the plastic surface of the disc. Do not want to resort to disc recovery service.
    don't want to give up yet.
    Most surfaces can be polished. I need to find a way for this one. Am I the only one who has encountered this problem with plastic protection sleeves sticking to and mottling the disc they are supposed to protect?
    Hopefully, one of the experts here will be able to solve the problem...
    Again, has anyone else encountered this problem? What is a solution, not what I should not do...
    Sergeant:
    Champion:
  • 214 Answers
I think you better don't insert such type of disks b'cos if you keep trying to read it may also damage the lens of your optical drive
Posted on Sep 13, 2008
    Master:
  • 763 Answers
Yup i agree with drcool once the cd is not readable it may not playable again. im sorry!
    Genius:
  • 1,239 Answers
Hi  you can find all solutions in the link www.how to mend it.com
  • ABHISHEK.C
    ABHISHEK.C Sep 13, 2008
    hi
    now i seen this solution in blueapple mobile search video.....................search as repair a cd
    President:
  • 1,952 Answers
  • Do not use strong cleaners, abrasives, solvents, or acids.
  • With a soft, lint-free cloth, wipe gently in only a radial direction (a straight line between the hub and the rim). Since the data is arranged circularly on the disc, the micro scratches you create when cleaning the disc (or the nasty gouge you make with the dirt you didn't see on your cleaning cloth) will cross more error correction blocks and be less likely to cause unrecoverable errors.
  • Don't use canned or compressed air, which can be very cold and may thermally stress the disc.
  • For stubborn dirt or gummy adhesive, use water, water with mild soap, or isopropyl alcohol. As a last resort, try peanut oil. Let it sit for about a minute before wiping it off.
  • There are commercial products that clean discs and provide some protection from dust, fingerprints, and scratches. CD cleaning products work as well as DVD cleaning products.
If you continue to have problems after cleaning the disc, you may need to attempt to repair one or more scratches. Sometimes even hairline scratches can cause errors if they just happen to cover an entire error correction (ECC) block. Examine the disc to find scratches, keeping in mind that the laser reads from the bottom. There are essentially two methods of repairing scratches: 1) fill or coat the scratch with an optical material; 2) polish down the scratch. There are many commercial products that do one or both of these, or you may wish to do it yourself with polishing compounds or toothpaste. The trick is to polish out the scratch without causing new ones. A mess of small polishing scratches may cause more damage than a big scratch. As with cleaning, polish only in the radial direction.
Libraries, rental shops, and other venues that need to clean a lot of discs may wish to invest in a commercial polishing machine that can restore a disc to pristine condition after an amazing amount of abuse. Keep in mind that the data layer on a DVD is only half as deep as on a CD, so a DVD can only be repolished about half as many times.
  • 958 Answers
Im sorry that i am the one to inform you but damaged disc are really un-recoverable.
the lens that reads the disc can not jump to scratches and plastic that is why it is no longer readable.
tnx 4 using fixya,
drcool
  • 19,396 Answers
Try cleaning CDs under tap water and dry them thoroughly with a soft cloth. May seem weird, but this often clean the CD better tan alcohol.
Ensure CD have no paper label on top before washing them.
  • 1 more comment
  • Ginko
    Ginko Sep 13, 2008
    If plastic migration is at a really advanced stage, then the only thing you can try is using a recovery software like this http://www.jufsoft.com/badcopy/cdrecover...">CD Data Recovering Tool.
    Often damaged CD are not recoverable.
    Back up as many CDs as you can.
  • Ginko
    Ginko Sep 13, 2008
    Toothpaste is generally abrasive, even if this method is popular, it can cause more damage to CD.
    If damage is moderate and the reader can start reading the disk and get the file allocation table, then you can use a software like this:
    Naltech Software - CD Data Rescue,DVD Data Rescue,Multi Data
    If disks are heavily damaged, and the data inside is important, you can send them to a data recovery company, the fee for the service will be expensive:
    Here is one example:
    Acodisc CD data recovery
  • Ginko
    Ginko Sep 13, 2008
    There is no way to polish it, it is not a pair of shoes. If you use any abrasive product, the tiny invisible scratches on the CD surface will damage it.
I'm getting 'No Disc ' Error on all the CD's that I tried. Can you help?
remove the cover and clean the lens with alcohol and tooth picks with cotton, try with audio cd, if your dvd play audio disc but not dvd disc you will need to change the pick up laser.
Apr 10, 2010 | Sony BDP-S300 Blu-Ray Disc Player
I have discs in my cd player but it says NO DISC.
The "no disc" messing indicates that the disc is not readable. This can be due to a dirty lens on the optics or defective optics. If you can gain access to the CD section, try cleaning off the lens of the optics assembly using a cotton swab and alcohol. Let me know if that does not resolve the problem.
Dan
Dec 02, 2008 | JVC MX-J10 Shelf System
Disc wont work
Hi AdalVI,
Your PS2 probably has a dirty laser lens. Below is a procedure for cleaning the lens on the big PS2. It does not work on the Slim PS2. Do not ever use alcohol on a slim PS2 laser lens.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Won't read disc.
Hi Crashley41 and Von281,
Since you have the bid Phat mode; you will have better luck at fixing your PS2.
This is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
If you still have trouble reading discs. Click on " Repair Directory" at the bottom of this screen. Then on the next page click on "Video Game Consoles". Pick a Repair shop to get your PS2 repaired. Fixya has some good ones dedicated to Playstations.
Nov 23, 2007 | Sony PlayStation 2 Slimline Console
Sony PS2
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Nov 07, 2007 | Sony PlayStation 2 (PS2) Console
Disk reading error
Hi Tyrell,
What kind of disc is it? The PS2 can sometimes have a dirty lens and not read discs. It does not matter if the Disc is new and unscratched.
  4. REmove the Warranty sticker to the right edge of the power socket.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  10. REmove the little white disc from the Cd tray lid.
  13. Put it back together, and your in business.
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
My PS2 will not play PS2 games, but it will play PS1 games
Hi
If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
PS2 Read Error
My PS needs help
Hi Coyneland,
Nov 02, 2007 | Sony PlayStation 2 (PS2) Console
PS2 Wont Play
Oct 30, 2007 | Sony PlayStation 2 (PS2) Console
64 people viewed this question
 Grubhead
Grubhead
