Question about Whirlpool GGX9868J Gas Dryer
Dryer whirlpool dryer code on the panel says, E-1 dryer stops and has to be restarted after a couple minutes ??????????
  • Al H May 19, 2008
    I am having the same E1 error msg with Whirlpool Electric dryer. Assume same thermistor problem. Is it located in same place. Do you have part number?
    President:
  • 878 Answers
Derf, E1 means an open thermistor. If this is a front loader, remove the lower panel by removing the 3 screws on the bottom panel. The thermistor will be sitting right behind the blower housing next to a white thermal fuse. The thermistor is the black one. If this is a standard model the lower panel should open by sliding a puddy knife on the two clips and pulling foward. The thermistor is in the same place as a front loader. Your part number should be 3976615. An easy job. Don't forget to kill the power to the unit when repairing...Good luck.
Posted on May 15, 2006
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
What does F-1 mean on a Duet front load dryer? Our dryer's lights will turn on but, the dryer will not start up. At first we thought the control panel was locked out. But, it wasn't.
The "F-1" error code means a failure occurred with the electronic controls.. This could mean that wires are broken, the electronics shorted out or a manufacturer's default error shut the washer down.
Prevention/Solution: The electronic control panel needs replacement. Find your dryer serial number and search for the part online. This is a lengthy job that usually requires a repairman unless you have dealt with and repaired dryers before.
If your dryer was purchased within the past couple of years, the dryer could be covered under the warranty. Visit the Whirlpool customer service page for more information or Whirlpool-Duet-Dryer-fault-codes
Hope this helps.
Jun 02, 2011 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
Electric dryer keeps stopping
Most likely, the operating thermostat has failed, and the high limit thermostat turns off the dryer when it gets too hot. When it cools down, it will start again.
Apr 06, 2010 | Whirlpool GEW9250 Electric Dryer
My whirlpool dryer just beeps when you try to start it. The panel is lit up the door is shut, push start and it just beeps...any idea what the problem is
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control Locked light is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If holding doesn't unlock the feature, it is likely a faulty interface. I am having the same problem with my Whirlpool dryer and it is the interface, but it seems that a lot of people are able to correct the issue just by pressing the End of Cycle button for 3 minutes.
Here is a link to parts, numbers, and prices from Sears:
http://www.searspartsdirec t.com/partsdirect/getSubComp.pd?modelNumber=GGW9250PW1&productCategoryId=0151200&brandId=1198&modelName=RESIDENTIAL-DRYER&diagramPageId=00001&componentDescription=TOP%20AND%20CONSOLE%20PARTS&documentId=W0508037&blt=06
Jan 09, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer shuts off after a minute or so
You have a bad motor . Only possibility .
Jul 18, 2009 | Whirlpool Dryers
Dryer stops after a while
it's over-heating it needs to be looked at, thermal fuses, lint buildup
Mar 24, 2008 | LG DLE5977 Electric Dryer
Whirlpool GGX9868J Gas Dryer Logo
133 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
