My front loading washing has twice had this problem. The model # is 970C47092-00 SERIAL# IS XC72808621. This is the secondtime this has happened. I put a load in it, set it and when I go to put the clothes in the dryer it has not gone through the cycle. The message today was E20. That's telling what the problem is,I presume.
  • 878 Answers
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
holla, Im not showing a E20 code on the tech sheet. There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys. If you see a different error code, post it. If not, I would suspect a clogged pump...Catriver.
Posted on Aug 04, 2007
  • 4 Answers
SOURCE: E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Posted on Mar 08, 2008
SOURCE: zanussi progress 1200 WASHER DRYER
This means that the filter is clogged. Get a towel (or two) in our case, and then unscrew the filter. It'll be full of lint.
Posted on Mar 19, 2008
Agent Dort
  • 216 Answers
SOURCE: E20 Error Code
Greetings jeanne1568,
Other consumers have reported this error message and found it relates to your "Coin trap assembly" being blocked, therefore not allowing all the water to pump out. The suggestion out there is to remove the front access panel, and remove the clamp that connects this trap assembly to the pump and clean it out.
I hope this helps.
Go Ahead. Use Us.
Posted on Jun 17, 2008
  • 1543 Answers
SOURCE: Visible water level in front-load clothes washing machine?
Yes, it is normal. There is water in the machine. One of the big draws for this style machine is that they use much less water than top load machines. If you stopped the cycle and opened the door, dug down in the clothes, you would find water. The machine fills a small amount of water (below the level of the door) and tumbles. As the water is absorbed by the clothing, the water level drops, so the machine adds more to maintain the water level. This is basically how the washer figures out how big your clothes load is and how much water that load needs. (Of course most sales persons at the big box stores and Sears have no idea how this works)
If you'd like, try running a cycle with no clothes to see how much water is in the machine. (It's not a lot) Now remember this: Because there is so much less water use than a top load machine, you must cut way way way back on the amount of soap and fabric softener used. Use no more than one tablespoon of HE (High Efficiency) soap (even less if it is 2x or 3x concentrate) and one teaspoon of fabric softener per load !!!!!
This should be a Fix-Ya for your question. Thanks.
Posted on Dec 14, 2008
Does GE have problems with washing machine model GLWN2800D2WS, Serial number HF17 1857G?
GE Washing Machines
Not cool not good reviews, your issue mentioned in several ways.
I have Samsung front loaders, love them. Direct Drive, amazing not brand new machines. I'd look at sears outlets they have tons of local stores no a days...
good luck!
San Diego, CA
Sep 20, 2016 | General Electric Washing Machines
3e error code washing
3E is an error code related to the motor speed or speed sensor. It could be a bad motor, or perhaps a foreign object impeding motor function. Depending on your expertise, you could tear down the motor assembly and check for problems, or else contact a repair technician. Given that it's happened twice, it will likely happen again.
Dec 19, 2013 | Samsung WF328AAW Front Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Kenmore front loading commercial washer door will not opne
You need to get access behind the front panel, taking the top panel off is probably best. Then you can see the the door release mechanism and release it.
Feb 09, 2009 | Kenmore 43042 Front Load Washer
Error code upsidedown F followed by an e
whats the model number on the washer and whats it doing and when get the model number off the serial plate and the serial number
Mar 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
