Question about Orion1934 19" TV
Snowy picture i drpped the remote and now all the channels are snowy, no clear picture, except menu
  • 10,594 Answers
Snowy picture is problem of bad Tuner or incorrect antenna pin connection. Please check Antenna pin has plugged correctly in RF input of tv. Dropping remote is not cause of snowy picture.
Posted on Sep 12, 2008
    Brigadier General:
  • 5,158 Answers
Check the channel the tv is on especially if you are using an external converter for the tv.... it should be on channel 3 or 4
Robert
  • Orion Master
  • 13,433 Answers
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
  • Ekse Sep 12, 2008
    Check all cables and connectors.
LG flatron plasma rz42px10 snow screen with sound
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2017 | Televison & Video
Hello. the particular setup we are dealing with is
Hi Guest, I can definitely help you with that, however if the screen is snowy we won't know if it's working until we get a picture.
To do that try changing TV2 to channel 60 and 73. If it only goes up to 69 put it on 60, if it goes to 73 then good. If still snowy, then go down to the main television and follow these steps. Menu -> System Setup(6) -> Installation(1) -> Modulator Setup(5). Go to TV 2 Out and change mode to Air if you put the TV2 on 60 and Cable if it's on 73 and select Done to save.Check the second TV for picture, and if it's still not showing then check cabling.
Once you have a picture back the remote should be working with it, if not feel free to post here!
Tommy Faust
DISH Network
Jun 19, 2010 | DISH Network IR Remote Control
No picture in a picture
The picture for picture-in-a-picture must come from somewhere. Try a DVD for the picture in picture. It may be the second tuner for the picture in picture that has failed.
Mar 30, 2010 | Hitachi 50UX26B/27K 50" Rear Projection...
Magnavox tv has cable channels 2-13 only. Lost original remote. Using a universal remote. Tried to auto program. It started scanning but when channel 14 came around, just fuzzy snowy picture all through...
The set needs to be switched from antenna to cable in the setup menu. It is capable of either antenna reception or cable reception. Ch 2-14 are the same frequency for antenna and cable but above 14 they are different. That is why the picture is stoping at 14. After you switch it to cable auto program again. Thanks for using fixya.
Nov 12, 2009 | Televison & Video
Snowy picture on VCR with only certain channels
In all likelyhood, you have a bad ground somewhere in the cable. Try other channels through the VCR. If the ground is the problem, there will be a cluster of channels that are snowy with the rest being clear. Check the cable itself and all of the connectors along it.
If the cable and connectors are good, the tuner or power supply of the VCR could be faulty and cause this as well.
Dan
Dec 24, 2008 | Sony SLV-N50 VHS VCR
Snowy picture
Usually a snowy picture means that you have a bad ground connection. You should see that some channels are beter than others. Verify that the cable connection is good. Try a different cable if you can. If that has no effect, than we need to start looking at the tuner itself. If you can change channels but just have a poor picture, chances are that a resolder of the tuner section will resolve the problem.
Keep us posted.
Dan
Jul 29, 2008 | Mitsubishi VS-50605 50" Rear Projection...
No sound or tv signal
Probably need the TUNER either fixed or replaced.
Apr 27, 2008 | Toshiba CZ27V51 27" TV
Akai PDP4294 - Snowy, pink & green picture
It is most likely a problem with the tuner, I would contact the place you purchased it or your nearest repair shop.
Feb 07, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Orion1934 19" TV Logo
194 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
