Tv problems It keeps switching from video 1 to video 2 to video 3 to tv, and all the while the menu keeps popping up and cycles through all the options changing them and then reverting back to the way it started..can you help?? Toshiba 32a43 having the same problem and im tired of seeing the video 1 2 3 and tv popping up. how to fix this issue .
  • 520 Answers
Have you tried taking the batteries out of the remote? Sometimes the buttons can stick.
Posted on Sep 13, 2008
2 Suggested Answers
jerryg50
  • 1673 Answers
SOURCE: Tv problems
There are a number of things that can cause this.
If you have a compact flourescent lamp in the room, this can cause some models of TV sets to go nuts, or not respond to the remote. These compact flourescent lamps use a frequency band that is close to the data carrier freqency of the remote.
Excellent article about compact flourescent lamps interfering with appliance IR remotes:
http://www.neptunlight.com/files/IR-and-CFLs.pdf
The other thing that can be wrong is there may be a fault in the keypad assembly on the TV set, or a fault condition with the uPC.
Jerry G.
Posted on Apr 19, 2008
On my technika TV menu screen keeps popping up,how can i stop this?
problem seems to be solved,i altered the auto time feature and it settled down
thanks for replying
Bob Hawksby
Mar 31, 2014 | Audio Players & Recorders
My tv menu keeps popping up every few seconds.
On the Front Panel Board Vol- vol+ CH- Ch+ power,menu Clean Contact switches this should fix problem if not then either replace board or Contact switches
Mats Electronics 1-800-628-1118
Dec 25, 2010 | RCA R61WH76 61" HDTV
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
1st time using component video connections on my onkyo
Yes, switch to the video input that you are trying to configure (i.e. video 1-4). Press the menu button on the receiver or the remote and cycle to video settings. There should be a setting that says "video output" or "output" - set that to component. You may also have to configure the Input for that particular setting. For instance, if you have an HD tivo going into component 2 but you want it to be Video 1. Select Video 1, hit the menu button and scroll to video setup. Select video input setup and cycle it to component 2. Next, use the menu to cycle to video setup, select video output, switch to component. This should solve your problem. As a sidenote, you may also have to configure the audio in/out if you're using digital coax or optical. Let me know if this works.
Feb 02, 2008 | Onkyo TX-DS787 Receiver
Function switch doesn't work
This is due to switch malfunction problem. Dust and corrosions shows these type of problem. Make one general service by technical person. Or if you have keypad lock system in your menu options lock your keypad control. The TV will work.
Aug 28, 2007 | Toshiba 32A33 32" TV
Tv problems
Jerry G.
Jul 02, 2007 | Toshiba 32A43 32" TV
Menu keeps popping up
Hi, heres your fix, very common problem usually caused (but not always) by using windex to clean the screen, replace the front control boards tact switches, replace all of them, part number is 23344443, end of problem :) BMW Rider
What do I do for tv switching from tv to various video modes and cycling through set up screens
the tactile switches on the control panel cause this problem . they could'be stuck or have some kind of contamination like liquid. or just bad . cost to repair aroud 60.00 dls if this helps please let me know
Jun 12, 2007 | Toshiba 35A44 35" TV
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
