Question about Casio Exilim EXZ75 Digital Camera
No Power on camera. Battery will not charge. Charger led flashes when tying to charge. Have another (older 2007) exact model camera and battery from this camera works fine within this camera. This suggests a faulty battery pack. Camera is just over 3 months old having no more than four charges. I would expect a replacement under warranty. Please contact me ASAP.
  • 4 more comments
  • ziggz Sep 13, 2008
    What do I have to do to call on my Casio Warrantee to get the problem below fixed????
    posted by ziggz on Sep 12, 2008
  • Anonymous Sep 13, 2008
    daughters camera won't turn on led flashes red when trying to charge
    Can somebody tell me how on earth you can 'speak' to someone from Casio support? Had a problem several years ago with a Casio QV-R1and this was repaired within 6 weeks via on-line support..FANTASTIC! This is why have stuck to the brand for so long. What has happened??? Please, please...anyone else have problem with battery under warranty as we must have legal rights ? Sale of Goods Act and 'reasonable merchantable quality' must come into act here.
  • nroyscot Sep 18, 2008
    battery wont charge,light keeps flashing on charger
  • Anonymous Oct 05, 2008
    SAME PROB...what do i do?
  • Anonymous Oct 29, 2008
    Won't the camera turn off if you have it connected to computer via USB? I can not get my EX-Z75 to turn on.
  • 3 Answers
I looked up the casio tech number online, and i called and got through right away. the lady said it is a very common problem, and they are sending me a brand new battery free of charge. no shipping or anything. it means the battery isnt taking the charge.
Posted on Oct 03, 2008
I replace new battery for my nikon coolpix p600 but still can not switch on. Please tell me how to fix this problem...thanks Larry
You will have to tell us what happens when you put a EN-EL23 battery inside the camera and you hook it up to the charger or USB. If the charger or USB is hooked up the Camera will Turn ON. The POWER LED will be GREEN. Another LED on the camera will FLASH GREEN. If this happens when you charge it you are halfway home. Change it until the flashing LED turns off. This means Battery is FULLY changed. Then REMOVE the USB or CHARGER and try to turn it on.
Jan 18, 2017 | Nikon COOLPIX P6000 Digital Camera
Battery charger flashing red
Although the manuals nothing says about flashing red light on charger, my best guess is the battery is defect.
Try to remove the battery several times and start the charging again and again. But when after a few attempts the LED starts flashing again, you better buy a new battery. When you don't use the camera for a longer period, make it a habit, to charge the battery every 3 months or so.
Jan 13, 2014 | Olympus Stylus 850SW Digital Camera
Battery led flashing
Try another cord/charger with the EXACT same power specs. If it still doesn't charge, Replace battery with a genuine Asus battery.
Mar 18, 2013 | ASUS Eee PC 1000HD Notebook
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Flashing LED on Samsung SBC-N1 Charger
LED flashing is unable to charge
Sep 05, 2009 | Samsung Cameras
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
C50 olympus power up
Is suspect the battery has been damaged Tell me more about the leaving in the USB port- this is not the normal way a battery is charged. Is it different for this model of camera?
Aug 14, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Rechargeable Battery won't charge
I think this is a general Fuji design fault in the camera circuitry. I have an older F455 which has exactly the same problem and I did the same - bought new batteries only to discover that didn't help. The only solution is to spend even more money for a stand alone battery charger.
Sep 07, 2006 | Fuji FinePix A340 Digital Camera
Casio Exilim EXZ75 Digital Camera Logo
93 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
