Question about Video Game Consoles & Games
Can not run musicalis Guitar universal workshop. Program installed on computer from disc.
Uninstall Java and install Java from the CD. I had the same problem.
Posted on Apr 04, 2009
I have original eyewitness encyclopedia space universe cd. but when i install it a error message shown in the computer. "[1058] the sound decompression software has not been install properly. please...
Hi ,
This product is not compatible with Windows 7 but it should run under Windows XP . If you are running under XP , I suggest you delete the program , reboot your machine and reinstall the program under Windows XP . If it still fails , you could need to reinstall Win XP or use the recovery disc . Launch the disc , select " install a new version of XP " and choose " repair " when you'll be asked to .
Make first sure you have installed SP3 and tested your program with XP fully updated .
Best regards ,
fanaudi .
Apr 22, 2011 | Dk Multimedia Eyewitness Virtual Reality...
I purchased chessmaster 10th edition and installed to computer when i hit the play button for startup it asks to insert disc 1 i would like to know why this is required when the program is installed ...
i am sorry to give u bad news, game CM is game that need disc to run the game because a lot of stuff that still need to run the program left behind in the disc. it was factory setting.
But u can use alternative way by make the disc to image then run it with daemon tool.
first u need program that can make image file like .iso, .nrg, etc. ( i use nero)
make an image file from CD 1 and CD 2 and save it in computer.
second install program that can make image drive to run image disc (i use daemon tool).
make one image drive then mount the image disc to the drive.
now u can play without real disc. (after finished play the game unmount the image disc)
hope this helpful
Feb 15, 2011 | Ubi Soft Computers & Internet
I've recently purchased the NI USB Guitar Link, which comes with two Behringer discs. I'm having problems installing the Behringer iAXE (volume 3) software. Couple of things to share: 1. When I attempt...
If you get beyond the 32/64 issue, check the audio setup for your audio device in your windows control panel. If your USB interface both recieves from your guitar and sends audio to your external amp, make sure BOTH the input and output to the USB are listed as the in and out in the "VOICE" tab when you go to the control panel and "Sounds and Audio device properties".:
Nov 22, 2010 | Behringer VT250FX Virtube Guitar Combo...
I need help to install this program
Hello Cryspycritte, Thank you for the clarification. Your program is definitely compatible with Windows XP. What you will need to do is put Disc 1 of Print Workshop into your CD drive. Click on your start button in the lower left hand corner of your desktop, then click run (located right above the "turn off computer" button.) A run box will appear in the bottom left hand corner. In the box type: D:\setup.exe (where D is the letter of your cdrom.) A setup window will appear with the final steps for installation. If you have any installation issues please post a reply. Thanks for using FixYa! Edward
Aug 24, 2010 | ValuSoft Print Workshop 2003 for PC
Guitar Hero 3 Won't Install
copie info. then format?!hope it helps! good luck. mart.
Aug 14, 2009 | RedOctane Guitar Hero III: Legends of Rock
Emedia guitar master not able to run after installation
Windows® Vista Error on launch:
“Director Player has stopped working” or “Macromedia Projector has stopped working” Most likely this problem is solved with the following steps:
  1. Click the “Start” menu and launch “Computer” from the right hand panel
  2. Navigate to the eMedia Guitar Master installation directory (typically this is inside your C: drive > “Program Files” folder)
  3. Navigate to the “Xtras” folder within your “eMedia Guitar Master” folder
  4. Delete the file called “SequenceXtra_1_9.x32”
Launch Guitar Master. It should open properly.
If the above solution fails to eliminate the problem, take the following additional steps:
  1. Click on the “Start” menu and navigate into the folder to the eMedia application.
  2. Right-click on the program icon and select “Properties.”
  3. In the box that pops up, select the “Compatibility” tab.
  4. Check the box “Disable visual themes.”
  5. If you can, check the box “Run this program as an administrator.”
  6. Click “Apply” and then click “OK.”
If you continue to experience problems with Vista, please make sure that your system is up to date. Download the latest updates for your operating system at support.microsoft.com. Get the latest version of QuickTime at www.apple.com/quicktime/download.
Dec 29, 2008 | eMedia Music Corporation Guitar Songs Vol....
Installaton Problem
why cant i install this program
Sep 27, 2008 | ValuSoft Print Workshop 2003 for PC
I am trying to install Resume Workshop on my new computer and it has Vista operating system
Most programs written for Windows XP also work in this version of Windows, but some older programs might run poorly or not at all. If a program written for an earlier version of Windows doesn't run correctly, use the Program Compatibility Wizard to change the compatibility settings for the program. To change settings for a program manually, use the individual program's Compatibility tab.
If changing the settings does not fix the problem, go to the program manufacturer's website to see if there is an update for the program.
How to Run the Program Compatibility Wizard 1. Open the Program Compatibility Wizard by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Jul 03, 2008 | Computers & Internet
Ulead dvd workshop 2
You can install and run a Ulead software for Windows XP on Windows Vista by running
the Program Compatibility Wizard. We do not guarantee full stability for Windows Vista though.
To run Program Compatibility Wizard:
1. Open the "Program Compatibility Wizard" by
clicking the [Start] button, clicking [Control Panel], clicking [Programs],
and then clicking "Use an older program with this version of Windows".
2. Click [Next] when the "Program Compatibility Wizard" dialog box comes up.
3. Select "I want to use the program in the CD-ROM drive" and click [Next].
If the installer is not detected from the CD-ROM drive, please manually browse for the installer executable.
4. Under "Select a compatibility mode for the program" step, please click on "Microsoft Windows XP (SP2)" and click [Next].
5. For the display settings, please click on "Disable Visual Themes" and "Disable desktop composition" then click [Next].
6. Click on "Run this program as an administrator" and click [Next].
7. Click [Next] to start testing the compatibility settings.
This will launch the installer so if you have your firewall enabled, it will prompt for a permission request.
Please grant permission for the setup to continue. 8. The setup will now run.
You can allow it to finish or switch back to the "Program Compatibility Wizard" dialog box.
9. It will ask you if the program ran correctly. Click "Yes..." if no other pop-ups appear.
* Try another compatibility setting if it reports a problem with the display. For the display settings,
enable the option "Disable display scaling on high DPI settings" as well.
10. For this next step click "Yes" to send the info to Microsoft and finish the process.
* Now that you have the software installed, you will also have to run the "Program Compatibility Wizard"
for the application to run correctly. Use the same procedure except for step [3],
select "I want to choose from a list of programs". Follow the same procedure for the other steps until you finish the setup.
Nov 16, 2007 | Ulead DVD Workshop 2 for PC
Video Game Consoles & Games Logo
70 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
