Question about Samsung RS2630SH Side by Side Refrigerator
Samsung rs2578sh flashing freezer temp indicator
My freezer temp indicator wont stop flashing. It is about 3 yrs old
  • yue_dre Sep 20, 2008
    samsung rs2578sh flashing freezer temp and the temp inside the freezer is warm,
  • Digit0 Sep 30, 2008
    I have the same problem, but with a Samsung RS21JGUS. The digits that show the temperature in the frezzer blinks and it gets warmer inside the frezzer. This occurs from time to time and then goes back to normal.
    Unplugging the power doesn't help.
    Anyone have any ideas on what the problem might be?
milten1
  • 1304 Answers
SOURCE: samsung RS2578sh freezer not working and temp
before you call for service
try the unplug reset method
sometimes this unit
freaks and that what happens
just unplug it for a few minuts hopefully it should clear up
bar that your could be looking at a new control board
Posted on Oct 29, 2009
Why would the freezer and fridge temperature indicators flash after a few hours of the unit being switched on?
Hi, some fridge freezers the indicators flash as they have not got to the right temperature yet. Also some freezers have indicators that will start flashing to let you know that the door has been open to long and the freezer temp has risen.
Jan 20, 2016 | Refrigerators
Kenmore coldspot, freezer frosted up then auto defrost and both freezer and fridge stopped cooling. unplugged and defrosted and now freezer works but not fridge. vacummed coils already. 3 yrs old.
Check the freezer fan motor.
Is it working>
If not,replace it.
Also you must replace the defective defrost parts.
Timer......heater.....thermostat.
May 08, 2011 | Refrigerators
MY SAMSUNG RS2578SH does not work in the cooler area
ck for ice build up in the freezer sde . this will block air flow and prevent cooling .. mm if ice is found you have a defrost failure . caused by a heater / thermo / or control failure .. mm hope this helped . mm
Oct 27, 2010 | Refrigerators
Samsung RS2578sh freezer not working and temp panal flashing
sometimes this unit
Oct 29, 2009 | Samsung RS2630SH Side by Side Refrigerator
I AM HAVING A PROBLEM WITH MY SAMSUNG FRIDGE FREEZER THE TEMP INDICATOR KEEPS FLASHING AND ITS NOT FREEZING?
Oct 22, 2009 | Samsung Refrigerators
What is proper operating temp of freezer/refrigerator?
0-5 F in the freezer.36-42F in fresh food.
Check for ice buildup on the back wall of the freezer. Check the freezer fan motor. Check the compressor fan motor.
Sep 06, 2009 | Kenmore Refrigerators
Stops cooling (fridge and freezer) then starts again
if turning the temp control up and then back down turns it back down, you might start with the thermostat. unless you have a local shop you like i recommend. http://www.appliancepartspros.com/partsearch/
Aug 17, 2009 | Frigidaire FRS26R4A Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
82 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
