Question about Yamaha HTR-5440 Receiver
Yamaha Receiver Rear-channel Problem
Hello, I am not getting any sound out of the rear channels from my Yamaha HTR-5440. Funny thing is, the headphone light on the display is always on, so I believe the problem is that it always thinks the headphones are plugged in, and it's automatically turning the rear-channels off. Any ideas? Thanks, Matt
  • Matt Ward
    Matt Ward May 15, 2006
    Ok, so I've taken it apart and looked at the headphone circuit. Again, the headphone output is working fine, it's just when I remove the plug the icon on the display doesn't go away.
    I know that when the plug is in, a circuit closes across the plug, but when the plug is removed from the jack, it becomes an open circuit. So it appears that there's nothing physically wrong with the jack itself (no unwanted short circuit).
    If I had to guess I think the problem is not with the headphone jack but rather with the processor that handles the signal that determines whether the headphones are in or not. Any suggestions on how I might diagnoss a problem with a processor to be sure? How do people handle problems with processors in the repair world?
    Thanks!
  • Matt Ward
    Matt Ward May 17, 2006
    So I left it unplugged overnight and most of the day today, but no luck. I also noticed tonight that I can't run the speaker test sequence, but I'm not sure if that's related to the same problem or not. Could this be because of a damaged processor or other replaceable component? Is there any way to do another type of reset that I am unaware of? Thanks!
    President:
  • 3,130 Answers
Have you ever used the headphones as the sensor switch could be dirty?? Or if not mybe got a glitch in the micro from a surge or something like that. Try unplugging for a good few hours and restarting again???. Good luck Let us know as the more info we get the better we can assist you.
Posted on May 15, 2006
  • Larry  Dillon
    Larry Dillon May 15, 2006
    unplug unit over night and let it reset.
SOURCE:
No sound from center channel yamaha 5440
mostly such behaviors are caused after the preamp of is faulty or the output section might have developed a problem after ...maybe the cable shorted or the amp fell and the board is broken. need a technician to confirm.
Jun 21, 2014 | Yamaha HTR-5440 Receiver
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
How to reset a yamaha 5440 reciever back to factory settings
Hold 'fm/am' and 'input mode' and press power button. Then cycle through menus using 'program' button until you come to the selection that says "preset inhibit". Then press 'preset/tuning' button to change it to "preset reservd". Then press power button to turn it off. When you turn it back on, it should be back to factory settings.
Dec 30, 2012 | Yamaha HTR-5440 Receiver
I have my HTR 6030 receiver hooked up with a blu ray and am trying to get true 5.1 sound. Have a blu ray disc playing and have put the setting on "straight" on receiver as instructed by future...
If you only have sound from the front left and right speakers when it's set to STRAIGHT, it means the audio source is only 2 channel stereo. As the audio source is from Blu-Ray, the audio should be HD if you are using the correct type of audio cable.
I really need more information from you to give a definitive answer. If you are only using a RCA type audio cable (red/white plugs) from the Blu-Ray to the Yamaha receiver then you will only get left and right front channels on the STRAIGHT setting. This receiver does not have HDMI, so you really need to be using a digital optical audio cable to get true 5.1.
Please can you let me know how the BD player is connected to the Yamaha receiver if you need further assistance.
Thanks,
BElectric
Feb 05, 2011 | Yamaha HTR-6030 Receiver
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Microphone for my YAMAHA HTR-5440
Let me make this clear to you that your Yamaha does not support Microphone but the trick is you can still do it. All you need is a stereo jack to a RCA connector cable.Check this out http://www.mediacollege.com/audio/connection/jack-stereo-rca-2.html It is easily available in the market. The stereo jack will fit into your microphone and the RCA to your Amplifier/Reciever. Plug the RCA into CD/Tape input but not in the Phono n do your thing. Let me know if this works,coz I'm really curious.
Jun 02, 2009 | Yamaha HTR-5440 Receiver
Left from speaker not working- Yamaha HTR-5940-6.1 channel
Redbird,
What do you have in the "multi channel input" jacks on the rear of the receiver? Those inputs Right, Left, Center, Surround R+L, and Sub are used when selecting 6 channel mode. They bypass the receivers surround processor board.
John W
Jan 10, 2009 | Yamaha HTR-5940 Receiver
Yamaha Htr-5560 Av Receiver ,will not turn on makes click-click noise only
had the same problem with a friend's 5560. it was a resistor on the rear center channel board, which is mounted right behind the middle of the heat sink. unhook the two ribbon type cables running to it from the board.
everything will work, except the rear center channel speaker. my friend never used the rear center channel anyway. in the meantime, he bought a new receiver, so i have an extra one for my workout room. woohoo. hope this helps.
Dec 12, 2008 | Televison & Video
Audio won't play on DVD - but it will play for CDs
Hello, you can verify that your receiver is working or not. When you are playing a dvd unplug the audio RCA plugs (red and white) from the back of the Sony dvd player. Touch the tips of each of the RCA plugs with your fingertip. You will hear a buzz sound coming from the speaker associated with the plug if the receiver is working\ i.e. touch the red RCA plug tip and the right speaker will hum...touch the white tip and the left speaker will hum or buzz. This will not hurt your system or speaker. If you do not hear the hum turn the volume to 3 or so and wet your fingertip and tap the tip of the RCA connectors. You will hear "pops" coming from the respected channel. I believe your cd\dvd is at fault. Good Luck!
barneyluc
Oct 02, 2008 | Yamaha HTR-5440 Receiver
No sound in rear and center speaker
Check to see if you have sound by selecting 5 chnl speaker setting buy pushing the program button on the amp. you should have sound comming through all speakers.
Oct 10, 2006 | Yamaha HTR-5440 Receiver
Yamaha HTR-5440 Receiver Logo
124 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
