I have an emerson tv/vcr combo model number vt1321. When I hook the cable up to it the cannels only come on up to number 25 or so and some of the cannels are the wrong ones. For example, channel 24 shows what is supposed to be on channel 75. I had another tv hooked up to the same cable outlet and it worked fine. I've tried manually adding the cannels in and nothing happens. The upper channels are still just blue. Please Help!!
This could be one of two problems, either the TV tuner card is set up to accept the wrong type of signals (which normally can be changed in the menu of the television) or the card isn't capable of translating the signal (with most cable companies going over to digital signals with their boxes translating the signals over.) My suggestion is to check to make sure the proper signal type is set in your menu (if in fact this is even an option for this particular television) and if that doesn't work get a generic analog digital cable box.
There are two settings for reception, one is a VHF/UHF setting for an antenna/over-the-air while the other is a cable setting, the two are not interchangeable. The only channels that the two settings have in common are the VHF channels from 2-13. You will need to access the menu setting and change it to Cable instead of Antenna.
Was this helpful?
Yes
No
Popular Solutions for Philips 43PP9202 43 in. Rear
Philips 43PP9202 43 in. Rear Projection Television
Hello I need some help and going way back with this model. I own a Philips Model#43PP92 0217 and the...
(More)
Hello I need some help and going way back with this model. I own a Philips Model#43PP92 0217 and the picture looks like its keeps rolling.. Any suggestions?
I have Same problem exactly with a 4 year old 43pp92 philips rear projection 43" HDTV,
just...
(More)
just the other day the convergence went out of whack, I was able to
converge the red and green pin cushions, however when i tried to
converge blue, it lets me converge the ones closer to the middle, but
Top right corner and Bottom left corners, the little crosses will NOT
adjust up or down, just left and right.
The color was mass .i fixed it by remote control unite was really nice . After turning it on -off...
(More)
The color was mass .i fixed it by remote control unite was really nice . After turning it on -off 2-3 times then shut off by it self .when you turn it on trying to go on then goes off after 3-4 secondI thought the convergence IC is gone .i ordered it finally it came after 12 days.I put new ICs but it is the same .you turn it on after 3-4 second it turns off.what is the problem?I am professional electronic technician.I uset to fix tvs long time ago.i dont have any experiance about rear projection tvs
