Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Canon ImageRunner 2270 - email addresses from AD to send scanned file
We have a number of 2270 printers/scanner/fax machines that we can scan a document and then send the file via emal (if you manually enter and email address). We want to do is connect to our Active Directory to access all email addresses in the company.
I've seen the 'Network Add. Book to select a destination from an LDAP server' button on the send screen, but this option is grayed out. Do we need to install additional software to use this function?
Thank you for your assistance.
Bill
4 Suggested Answers
  • 82 Answers
SOURCE: Canon imageRUNNER 5000 scanner
yes it can if you have the scanner driver borad loaded in the machine
Thank You,
Mikey
Posted on Apr 06, 2008
  • 25 Answers
SOURCE: Imagerunner 2220i - Scan-to-email Configuration
http to the machine and its under general settings can't think of exactly where off the top of my head
Posted on Nov 03, 2008
gkhairallah
  • 13 Answers
SOURCE: ldap connection issues. Issues connecting to LDAP
You need to change the base DN to match your active directory domain.
So, if your active directory DNS domain is: example.com then your DN would be: dc=example,dc=com
Hope this helps.
Posted on Jun 04, 2011
Fines not sending to email
try to scan it one by one as your scanner and processor is somewhat slow or defecxtive
May 17, 2013 | Canon imageRUNNER 3225 Black and White...
I am trying to setup this imagerunner 2270 as network printer/scanner. it prints okay but i cannot scan, downloaded scan gear too
Do have some sort of scanning software like OmniPage? The scan gear is used as an twain interface between the copier and the computer. Hope this helps.
Feb 02, 2011 | Canon imageRUNNER 2270 Copier
How to set ip address in canon ir 2830 i want network scan in this machine and send me complete information about net work scan
I need fax facility of my canon ir2830 network machine. pl let me know how to setup for fax in my canon ir2830
Dec 31, 2010 | Canon imageRUNNER 400S Copier
I have ir6020 copier. i cannot scan file to small business server 2003
Dear brother plz use the Canon Network Scangear software to scan the copy to system but it is a Black and wight scanner, so u can get the B/w scan copies on the meachine.
Note : Plz put the Scaner online working with scangear.
Jul 17, 2010 | Canon imageRUNNER 2270 Copier
How do you scan a file with more paper than feeder will hold? Don't want to split the file up and scan as 2-3 documents, want to scan complete file.
do you haave url send if you do then this is easy you can scan the large folders in the mailbox then enter a email addrerss for the mailbox and send the email address as a link and others can retrieve the data from the machines mailbox
Feb 03, 2010 | Canon IMAGERUNNER 6570 Copier
Canon Imagerunners 2270 and inbound email.
i know that "Mailbox" on Canon copiers is used just for storage personal scans and modify.
You can try to send an email to canon address, see what happened.
For your question, i don't know  it is possible. In this case Canon copier should be an email server.
Oct 04, 2009 | Canon imageRUNNER 2270 Copier
Scanning and send to email
  1. Setup your mailserver IP address in the smtp server addres and asign a mail address in the same domain.
  2. Make sure sure your copier is register with a send kit that your obtain from the dealer.
Jul 01, 2009 | Canon ImageRunner 2220I Copier
Scanning from a canon 3220
Yes, the type of scanning mentioned by the previous answer is called 'pull scanning' and you will have limited functionality. You have to load the document on the copier, turn on the scanner (nobody can use the machine now) return to your desk which I hope is not far from the copier because the doc stays there until you 'insert picture from scanner' then the machine scans the document and you run back to the copier to get it before someone throws it in the trash! It's a free system but limited. To have a fully functioning 'push scanner' where you send a doc as you stand at the copier to either a file on your computer, server or an email address you would need a universal send kit installed. If your machine has one you'l see the option tab called 'SEND' along the top of your screen. If you have this you're in luck. All you need is to enter the necessary network and email settings which can be done by any half decent network administrator vis the 'system settings' area from the addtional functions screen (accessed by pressing the head key with a star in it). Once this is set up merely select the 'SEND' tab and insert your document. In the top right hand corner will be a drop down menu reading either 'FILE' 'EMAIL' or 'FTP' If you want to send it to a shared folder on your network (anywhere) you select the 'FILE' option and then use the drop down menu in the centre of the screen to search the network for your shared folder. Select it and then press ok then the start key - IT'S GONE - IF YOU'RE LUCKY. To send to email you just select the 'EMAIL' option and enter the email address of the recipient and ok then start and you're in business provided that all the network and email settings are correctly entered and permissions for network access is set up. The machine needs a email account registered for it as well. I'm tired now - good luck.
Feb 17, 2009 | Canon imageRUNNER C3220 Color Copier
Thank You,
Mikey
Apr 03, 2008 | Canon imageRUNNER 5000 Copier
Won't PDF to email
I had the same issue when migrating between exchange servers. basically the scanner settings were pointing to the old exchange servers IP. I set that to the new IP and it resolved the issue.
Dec 18, 2007 | Canon ImageRUNNER 3570 Copier/Printer
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
394 people viewed this question
old marine
old marine
